Uneven Lift?
trevo_man
I had a shop install the following lift on my rig a couple months ago:
OME 881 Front w/ Nitrocharger Sport 90004
OME 890 Rear w/ Nitrocharger Sport 60028
Occasionally I have noticed that the driver side sits slightly lower than the passenger side. I measured today, and both the front and rear are sitting 1/4" lower than the passenger side.
I also noticed that the top of the passenger strut doesn't looke quite the same as the driver side.
Passenger Side:
Driver Side:
I am relatively new to the lift game, and really I just have two questions...
1. Does it look like the passenger strut was not installed properly?
2. Is a 1/4" difference in height per side pretty standard, or is something wrong here?
Thanks everyone!
This is common. And speaking from experience. Driver side is heavier do to battery, steering colum dew other things. I went and added OME 10mm spacer in back. On driver side.
Thanks everyone!
A lot of us have this problem very easy to fix. Toytec makes 1/4'' top plate spacers. Im running this and it fixes the lean. Might need a 10mm for the rear too.
At least you have duratracs
KO2's > Duratracs
Thank you! Good to know it is common, and my lift wasn't botched.
The top pic, the spring may not be seated all the way. Hard to tell from the pic though.
If it isn't seated correctly is there an easy way to find out short of disassembly?
I am running OME and from what I read and from my experience is that the springs are side specific. Longer ones go in the driver side to compensate the extra weight as previously mentioned. Spacers will def work but also check if the longer ones are on the drivers side.
Try swapping the struts. Even if they are both seated correctly it's still likely to have a lean. Get the spacers we mentioned. It will work
I'm running Toytec Superflex in rear. They make the driver side rear cool taller then the passanger side. I still had driver side sag. Even called Toytec complaining. The guy on phone said sorry. And that he has his coilovers in front at different settings to compensate for the lean. So I went ahaid and only put one spacer. OME 10mm in back. Like I said. Pretty common. More weight on driver side.
From some research on Yotatech, and after a call to Cruiser Outfitters, it does sound like at least the rears (OME 890s) are side specific. Supposedly the tags are marked "A" and "B," with "B" being driver and "A" being passenger side. I looked at mine, and neither tag as an "A" or a "B." They both look identical, and read "OME 890 O/N 502594" on one side and "0715" on the reverse. Can anyone confirm if the 890s are side specific?
The rubber insert don't look seated. That could be part of the issue.
I might have the shop that installed it take another look. Thanks!
As I recollect, Side A is the driver's side on my 906s. Would the 890s be the other way?
So I looked a little harder and I do have 890 "A" installed on the passenger side and 890 "B" installed on the driver side.
Per Cruiser Outfitters:
"These A and B designations represent a slight free height difference of the coil and are intended to be utilized on a specific side of the vehicle to eliminate or reduce lean. In the case of US spec Cruisers and installations (Left-Hand-Drive) you will put the taller B coil on the drivers side of the vehicle (left side) and the slightly shorter A coil on the passenger side of the vehicle. "
According to the OME Guide however, the 890A = 440mm Free Height while the 890B = 430mm Free Height.
So if I am understanding this correctly the "A" spring has a longer length of spring and thereby should probably be on the driver side. Despite the dozens of threads that indicate the opposite.
I can't totally remember but I read the A & B tags are different for export springs. "A" for driver and "B" for passenger. I put my springs side by side and the "A" was def taller so it went on the driver side. I did this with my 880's as well. One was a little taller so I did the same. Both front and rear are even.
I think my 906s were 'export' springs, too. Truck was even with A on driver side. They are off right now due to my frame swap I'm doing. I did not notice if A was longer. I'll look into this before they go back on later this week.
Mike Sargent
