Unner's Build, 2001 T4R 4x4
[MENTION=116877]fourfive[/MENTION]
So here's how I did my pinch weld mod. I didn't like the way that most do it with cutting the fender liner, so I didn't do that. I also couldn't find a detailed write up on it for 3rd gens so here's my contribution. I know I like to be able to see and visualize things before I dive into them so maybe this will help someone.
Most of us that have installed 33" tires or larger have some sort of rubbing. I was rubbing on my aftermarket mudflaps and the pinch weld fender liner area. This was from just driving out of the driveway quickly with the wheels turned (Trying to make it rub). I'm sure it would have been worse off road and I don't want to chew up a $1,000 set of tires so I took care of it ASAP.
Note: Also have your caster set as high as it will go, this puts the wheel farther forward away from the pinch weld, therefore reducing rubbing.
I'm running Cooper ST Maxx in 255/80/17 with 1.25" SpiderTrax spacers on OEM 5th gen trail wheels.
The first step is to take the wheels off. Here's what the rear fender liner area looks like with nothing done. The pinch weld is hidden behind the fender liner. That little hump is what you are most likely rubbing on. You should be able to see where you are rubbing by the "witness marks" the tire will leave back there.
DSC07466 by Unner Unner, on Flickr
Now you need to remove the fender liner. I had to pull the lower two screws for the fender flare, and the lower screw for the fender liner. Take the fender liner and tie it up to something. I tied mine up to the top of my coilover using a metal coat hanger. The material is thick and flexy. So long as you don't crease it, it should go back to its original shape. There are also a couple of these little plastic plugs that you will need to remove. They're a pain to get out. Some of them come out cleanly, some of them I had to break out. I bought a bag of 10 a couple years ago so I always have a few on hand. Toyota lists these as "grommets" when you look for the part number.
DSC07457 by Unner Unner, on Flickr
Now this is the pinch weld. This is what we will be "modifying" to create more room. Some people cut this off, I didn't want to do that because I don't know the structural implications that would have and water intrusion seems easier if you cut it. I felt that bending it over would be better.
DSC07458 by Unner Unner, on Flickr
I started by getting an adjustable wrench, setting it to the thickness of the pinch weld, and bending it over towards the engine. I was able to get it started like this. The very bottom is the easiest as it is only one layer of metal. The top is second because it is only 2 layers, and the middle is the hardest because it has 3 layers of metal. Once it was started I couldn't bend the middle part anymore with my little adjustable wrench, so I got the 4 pound hammer out :)
DSC07461 by Unner Unner, on Flickr
Now carefully hit the pinch weld over until it is flat. The lower part can be bend a little more than 90* to provide additional clearance. Be careful not to hit the plastic plug. I did and it cracked, so I had to seal it up with RTV since no one had a plug locally.
Some people on other forums said they were able to preserve the paint by wrapping the hammer in rags and such. That was not the case for me. Mine chipped and cracked, so I took a wire brush to it, and then painted over it with some chassis paint. After the paint was dry to the touch I went over the end of the pinch weld with some RTV just for good measure. Now repeat this process on the driver side.
DSC07464 by Unner Unner, on Flickr
DSC07479 by Unner Unner, on Flickr
Now that that is done, replace the fender liner like it was and get your heat gun out. I set mine to the highest setting, and started heating the area around the pinch weld. I used some interior trim tools to poke at the plastic and reshape it so it sat flat against the fender and make sure it wasn't getting too hot. The plastic does become very flexy, but it doesn't hold it's shape very well. To make it hold it's shape you need to heat it up, and then quench it with a dripping wet rag while pressing it into the shape you want. It took two passes on mine to get it to the shape I wanted. I wrapped the corner piece up around this metal bracket to make the fender liner more stable.
DSC07465 by Unner Unner, on Flickr
This is after the first pass with the heat gun.
DSC07470 by Unner Unner, on Flickr
This is after the second pass with the heat gun.
DSC07472 by Unner Unner, on Flickr
Here's a shot from underneath showing the clearance gained, and how I folded the bottom corner over that metal piece to help hold everything in place.
DSC07478 by Unner Unner, on Flickr
Now I went and trimmed my mudflaps back some more, and remounted them. This time using a rounded screw head just in-case the tire comes into contact with it.
DSC07481 by Unner Unner, on Flickr
Here's the final result. It took me a couple hours to do it, but I was waiting for coats of paint and RTV to dry. I'm very happy with the results, it looks OEM unless you really really know what you are looking at, and I didn't have to cut the fender liner.
Passenger side:
DSC07480 by Unner Unner, on Flickr
Driver side:
DSC07484 by Unner Unner, on Flickr
Hopefully that will help someone. I haven't rubbed at all since I did this. It might be easier to cut the fender liner, but it's not worth saving the 30 minutes of time it takes to pull it back, and reshape it with the heat gun.
I was gonna give you till the end of the week before I started blowing you up about your pinch weld mod :lasercannon: Thanks for the write up and pics, your work looks great.
I meant to get it posted up earlier, but I was super busy the last couple weeks with moving back to SC for the summer so that didn't happen. Also didn't get internet installed until Wednesday so that hindered my ability to post pictures. Glad you like it!
Very nice Unner. Looks great.
I have to ask though how you really like the Daytona jack....
Thanks! So far I like it. We bought this to replace one of the cheaper harbor freight jacks. One of the low profile, high lift ones. We had it for maybe 2 years and all of a sudden it wouldn't hold pressure. It would sink if you had any weight on it. Tried bleeding it, topping off the fluid, changing it, etc. and none of that fixed it. Tried to find parts for it and you can't buy parts for it apparently.
From our research it seems like most of the jacks are "throwaways" at this point, you can't really get parts for them and you just buy a new one when they go out, unless we're talking about the really high end ones.
The Daytona is also from harbor freight, but has a 3 year warranty so that's good. Haven't used it a whole lot, but it lifts the 4Runner easily, goes high enough that I can get my front wheels off the ground lifting from the frame with no wood blocks or anything, and seems to be slightly more controllable when you release it. I like that it has a bigger lifting pad on it too.
About to head down to Charleston and do some exploring, and maybe some fishing too.
Have a good time. Make sure the wallet is thick with green. I think the trout are running. If you get offshore the dolphin (dorado) are supposed to be running thick right now.
On the fence concerning a jack. Like the Daytona but really enjoy the low profile one that has the pressure release knob on the handle. Having rebuilt a couple of cylinders it is sad to know that parts are non existent to repair them.
[MENTION=157474]Friday88[/MENTION]
Here's my MPG's over the last 2,000 miles with the new tires.
16.2 - Mix of interstate and city
16.3 - Mix of interstate and city
15.2 - All city, driving forest roads to the river, etc.
17.8 - All highway, some interstate, some back highways
16.3 - Some interstate, some city
16.5 - Some interstate, some back highways, a lot of idling
17.4 - Some interstate, some back highways
If I had to make an educated guess I'd say my MPG is 15 MPG if I'm driving only city, stoplight to stoplight, slow going.
If I'm driving all interstate, 70 mph, I'd say it's 17 MPG.
If I'm driving all back road highways around 55 mph I'd say 19 MPG.
Not bad in my opinion. AC on or off makes a big difference, as well as wind. If you're driving into the wind you're screwed. I don't think I saw much of a change in MPG from my other tires. Maybe 1-1.5 MPG at most.
In other news a couple weeks ago I changed my fuel pump as preventative maintenance. I used [MENTION=123173]Jhelms[/MENTION] build thread. He has a write up on page 6 that is fantastic! Thanks so much!
The only think I could not figure out was how to disconnect the check valve. So I lowered the tank all the way making sure not to stress that hose and that gave me enough room to pull the entire fuel pump unit out from under the car with a little working around the body and frame.
The inside of the tank was really clean.
IMG_20170509_105840699 by Unner Unner, on Flickr
IMG_20170509_105821471 by Unner Unner, on Flickr
Cleaning the sender with an eraser.
IMG_20170509_104613250 by Unner Unner, on Flickr
Old fuel pump.
IMG_20170509_103642767 by Unner Unner, on Flickr
IMG_20170509_103639240 by Unner Unner, on Flickr
There was nothing wrong with my old fuel pump, but for $75 and 3 hours of my time it was well worth not having to worry about having a really bad day later on. And cranking the car 10-15 times is not enough to relieve the pressure in the fuel lines. I thought it would be good, but it was not. I sprayed fuel all over me and every where else... Also I couldn't figure out/didn't want to figure out how the pin on the gas tank strap comes off so I just took off the outer side where there is a bolt.
I also changed my transmission fluid and front diff fluid. Both fluids looked really good coming out which is always nice. I changed them a little early, something like 25k miles. While I had my engine/transmission skid plate off I noticed there was a mark where the powder coat had been rubbed through.
IMG_20170511_104937321 by Unner Unner, on Flickr
Over a year ago I started getting an annoying clunk when turning, backing up, etc. I thought it was my LCAs so I replaced those. Then I thought it was my transmission mount. Neither of these fixed it (both probably needed replacing anyway so I don't feel too bad). Then I noticed my transfer case skid plate was hitting my transfer case so I added some washers and put the engine/transmission skid on top of the transfer case skid in the layering of them. The clunk went away, but then came back a couple days later. I've been living with it for awhile now, and just chalked it up as a non issue. When I say this spot on the skid I knew I had contact there with the cross member that runs under the steering rack. I made spacers for the transfer skid plate using 1/8" aluminum bar stock and then layered the skid plates the way they are supposed to be. NO MORE CLUNKING!!! Also the aluminum is much easier to line up than 2 fender washers on every bolt...
Now I just need to get rid of this annoying fast paced squeak I have in the rear. It isn't dependent on speed or tire revolution, but seems to be more distinct when I turn the wheel left and unload the driver spring. When I turn right the noise goes away. I'm thinking it has something to do with the clear tubing I still have on that spring on the driver side rear. I put spiral cable wrap on the other side and it seems to work much better and looks way cleaner. I'm gonna pull the tubing and see if it goes away. Then I'll replace with the same spiral wire wrap I used on the passenger side. I hope its that... I don't think it is my rear sway bar bushings because I just replaced them and greased them up good when I got back from Moab. I don't have any grease on the end link bushings, but I'm not sure those need grease. I also haven't had grease on them in forever so I don't know why they would just start squeaking now.
A couple weekends ago my girlfriend and I went camping near Chattanooga in Johns Mountain WMA, part of the Chattahoochee National Forest. Nice campground, we were the only ones all weekend which is always nice. Didn't get any pictures of the truck, but I grabbed a few of the creek that was a couple hundred yards from the campsite. Nice cool creek you could walk around in.
DSC07495a by Unner Unner, on Flickr
DSC07490a by Unner Unner, on Flickr
Charleston actually wasn't too expensive for me. I camped in the Francis Marion National Forest for free and kept everything else pretty cheap. Only ate out once (Hannibals Kitchen has great food, and really cheap too), and spent most of my time there just driving around exploring. Being by myself made it cheaper too. I didn't get a chance to go fishing unfortumatley. I didn't get out to the beach until almost noon on Saturday and nothing was biting then so I passed on getting set up. Sunday I wanted to go, but the weather was doing weird things so I just went downtown and walked around there before I headed back.
The low country is beautiful with the huge Live Oaks, Spanish Moss, and Palms everywhere. The humidity was killer as well as the bugs, which seemed to be much worse in the morning than they were at night.
Downtown was really nice. The entire area kinda reminds me of New Orleans, but cleaner, nicer, and probably safer too...
Here's some pics.
DSC07528 by Unner Unner, on Flickr
DSC07530 by Unner Unner, on Flickr
The Angel Oak. A massive 400 year old tree.
DSC07539 by Unner Unner, on Flickr
DSC07542 by Unner Unner, on Flickr
DSC07558 by Unner Unner, on Flickr
DSC07589a by Unner Unner, on Flickr
DSC07591 by Unner Unner, on Flickr
The campsite. Not all that secluded from the others camping there, but it was nice and easy to get to. If you are tent camping the sites are a little further off the road. This was Halfway Creek Primitive Campground. I just slept in the truck.
DSC07597 by Unner Unner, on Flickr
DSC07604 by Unner Unner, on Flickr
Beautiful homes downtown.
DSC07605a by Unner Unner, on Flickr
DSC07606a by Unner Unner, on Flickr
DSC07610a by Unner Unner, on Flickr
DSC07623a by Unner Unner, on Flickr
DSC07628a by Unner Unner, on Flickr
DSC07630a by Unner Unner, on Flickr
DSC07578 by Unner Unner, on Flickr
It looks like you had a very good time. I could add a slew of addition info to each pic but I won't. I will say that...
My uncle and aunt live on the river on the back of Folly Beach. They have received a torrent of rain there today. They like retirement there but the people on the weekends can be overwhelming. I lived on the second row there for a summer in college.
In the picture of the house on the Battery with the BMW in front of it there is a seven story building (the Fort Sumter Hotel) to the right of it past the parking lot. My grandmother lived on the third floor for nine years, unfortunately without a view of the Ashley River. President JFK had a fling there with some woman (imagine that) until his father caught wind and had him stationed in the Pacific in 1942 I think.
In the FMF there are or used to be a couple of motor cross/mountain bike trails for the dedicated weekend warriors. I was riding with some college friends one evening in the fall of 2000 when my buddy stopped for a flat. I was helping him change it when we heard some serious crying, wailing, like a baby. Then about 100 yards to our right in a field came out of the grass a cougar and her cub. Extremely neat. The postman for the area and his wife lived in a trailer near the trail head and told us that cougars had gotten on the roof of their trailer before. Back in the 70s he had seen one climb a pine tree with a dead doe in its mouth. The big cats are all but gone today. My 4runner's original owner actually still lives on Awendaw Creek.
Your truck, your thread and all the pics are incredible.
Great work. Wish I'd followed sooner.
So many threads to read...
Thanks! Glad you enjoy the truck, thread, and pictures. I plan to keep all of them going strong. I'm planning at least two more big trips this year hopefully. Lots of pics to come from them too.
The parking on peoples front yards in Folly Beach really confused me. I've never seen anything like that... That would irritate me greatly to have people always parking on my yard.
That's crazy about the cougar. I never knew we had big cats like that down in this part of the country. Unfortunately I saw no cougars while I was there. That would have been really cool, from a distance.
Where I camped showed my location as Awendaw on my phone. I was probably very close to your 4Runner's original home then!
Truck is looking great! Really like the look of the trail wheels on your rig, and thanks for the pinch weld mod! I like not having to hack at my truck!
Thanks man! Glad the pinch weld mod is of use to you. I hate hacking the truck too!
