(UPDATED) Help me choose some UCA's Now down to 2 options
I would say the Dirt Kings. The Icons wil require more maintenance
This^ Also, I know you narrowed it down to two options but I would highly recommend you consider the Dobinsons (ball joint like the Dirt Kings) as they don't require maintenance at all.
I’m gonna just leave this here.
Your stock ones would do perfectly fine for daily driving and "overlanding".
Per your last UCA question thread. Why not just run your stock ones with your lift until you get your wheels in and then put on the JBAs.
I was told that when you lift the 4runner 3 inches you have to change the UCA's , it's in a few threads on here somewhere.
It's recommended, not required though. There are several trucks in a few threads on here running 3" lift on stock UCAs. What specific lift did you buy for the 3" lift in the front?
My Eibach lift is 2.75" in the front on the lowest clip setting, no issues on stock UCAs. I've seen people set the fronts to the second clip which should net over 3" and have no issues.
I'm no mechanic and these are just my opinions from my own research over the years. Not saying issues can't or won't present themselves, but I don't think it's a requirement.
Plus out of all the options you've researched, why not look at SPCs? They will work with your stock wheels and they are adjustable for later when you do negative offset wheels and may need more caster. The price is not much more than JBA.
Like bmy1287 mentioned, it’s not required but the added caster you get from an aftermarket upper control arm will make the driving experience much better at those lift heights.
And also there is another reason to get aftermarket UCA, even if your lift is 2”. When you upgraded your front coilovers with 2.5” , in an order to clear it.
I wanted to go with these originally but I want something that will work with Stock wheels and tires for a few months until I get my SCS wheels.
JBA STD High Caster Upper A-arms for 2005-14 Toyota Tacoma, 4Runner, FJ Cruiser
FWIW - if you use stock arms for a while you'll end up having to get another alignment. One when you put the lift on and another when you change UCAs. So I'd probably buy the Dirt Kings and the $100 you save on the second alignment covers the cost difference.
Yeah - they're all overpriced. They really should be more like $2-300 for a set.
Thank you for all the help guys. I will be going with the Dirt Kings and if I need to upgrade for some reason I'll sell them and get the uniball, (Whatever that is).
Now I just need the rear bumper to get here from the powder coat and find someone to help me install it.
No, they are $49, but as mentioned earlier check with Mike @ ORW in El Cajon. They come in either red or black.
I was just there at ORW yesterday and contemplating between the Icons and Dirt Kings. I'm loving the affordable price for the DK, but i get a lot of recommendations to spend the extra for the Icons.
What's the biggest difference between the two that will persuade me to save up for the Icons instead?
Eibach Stage 1 kit
33s
-10 offset wheels
Eibach Stage 1 kit
33s
-10 offset wheels
What benefit(s) do the Icons buy you for the extra money? Uniballs may actually wear out faster and require more maintenance, can squeak, and for our application not provide any additional useful range of motion. Can't go wrong with Dirt King for this setup, but to each their own.
Tx470
