Use 4x4 or not?
I don't want to be the one to find out if that's true, I have had it in the red a few times and didn't even notice a limiter kicking in. It was not for long and I was not really looking for it also. Do we have a speed governor also, I have only gotten to 100 once.
I saw 109mph on my speedo (approx. 113 real) in 2WD on a trip last week before I let off. Doubting we have a speed governor, but might have chicken-ed out too early to find out! Surely someone on this forum is more Evel than I.
Respecfully - No. I'm not. I'm not just a web wheeler. I completely understand the part time 4wd system. I have a degree in physics. I've also broken transfer case shafts and built transfer cases from parts. 40" tires and low gears is hard on drivelines. Even then I can drive circles all day with the front and rear locked up in my fj40 without worry. Tires on asphalt simply cannot generate the friction that a bouncing wide open throttle run through a rock ledge can. Not even remotely close. If you can't at least do that, the vehicle has no business going offroad. Hell, a Honda accord can do a front dig without breaking axles.
I'm 100% fully aware of what's inside our transfer cases, how the shafts and chain drive operates. I understand that there will be scrub in turns, and it will put more force on certain driveline components. However IT WILL NOT CAUSE DAMAGE. Not only can I get away with it, I can drive in 4hi for the rest of the life of my 4unner and not have significant issues with driveline failure. Yes it will wear out tires faster. Yes it will get worse mpg. It might wear out ujoints faster? Otherwise, it's not really going to have any noticeable effect.
This issue isn't a close call. It's kinda silly that we're still arguing about it. Yes the best practice is to use 4x4 when you need it, and leave it in 2wd when you don't, but no it's not going to hurt a thing to drive on pavement in 4x4. Not for 10 miles. Not for 10,000 miles.
what does Toyota have to say on the subject?
It get scary at about 95, it's not a race truck. I would like to hear what our max speed is.
imo I don't think I want to run a high center brick at 115mph.
I've run mine up to about 91 and it was solid but felt floaty.
and btw this isn't me, just a youtube I found.
Do you think we can do that in 4 lo on a residential street with good traction? [emoji12]
While we are on the topic:
From the Toyota manual: H4 (high speed position, four-wheel drive)
Use this for driving only on tracks that permit the tires slide, like off-road,
icy or snow-covered roads. This position provides greater traction than
two-wheel drive.
You should drive in four-wheel drive for at least 10 miles (16 km) each month.
This will assure that the front drive components are lubricated.
My opinion is the truck will not explode and it is a small chance any driveline components will be damaged if using 4x4 on dry pavement for a short trip of city driving but if anyone really thinks to prove a point they will drive around with 4x4 and rear locker locked (assuming the truck is actually driven on city streets and not just a trail toy) then I say :eek: be my guest and take videos because that is going to be a jumpy, annoying ride.
BillM777
