Using the key fob to open all windows?
RobS10
Member
Do I need Carista programming software or the Dealer to program my ORP key fob to roll all windows down at once on a 2022 ORP, or is it already enabled and just a couple button pushes?
You can get a trial subscription to Carista, do all the programming you want (including the windows) and then cancel the subscription. I used an old ELM OBD2 dongle I had laying around. Like this one: Amazon.com: OBD2 Scanner Bluetooth Code Reader for Android Windows, Auto Car Diagnostic Scan Tool Odb2 OBDII Adapter for Check Engine Light for Torque Pro, OBD Fusion, DashCommand, Car Scanner App : Automotive
Can a plebeian like me, given that I am willing to spend enough money, obtain TechStream without being associated with a dealer / being a certified mechanic?
Looks like Carista will allow quite a few customizations. Don't know about I think you can get Techstream on a short term subscription...
TIS
believe the trial is only if you purchase carista dongle at $29.99. I have a fixd dongle and downloaded the carista app. I can do one month at $9.99, would change a few things on the audi and 4runner. 4runner changes would be use of key fob to open/close windows, and get rid of the seatbelt chimes
What is the just dongle if you buy it somewhere else?
basically any obd2 dongle could work, one posted in this forum at $12, but then another $9.99 for one month on the app. If you dont have one probably just better off buying one, you can use multiple apps with a dongle.
I don't have a dongle...so just get the dongle that comes with Carista? Not really much more than the one on Amazon.
I brought our 4R in for an oil change and asked how much to reprogram the vehicle to roll all windows down, and the guy said they would charge over $100. Uh, hard pass on that...
Is there any danger to using Carista? I figure I can also turn off the seat belt alarm and a couple other things, but don't want to create problems for our new truck
wouldnt be an issue plus you can always change it back if you dont like it.
Looks like Carista is even endorsed by The Car Car Nut :D.
Two more questions before I plunk down the money...
1. Is there a way to roll all windows up as well as down, and does up or down work for the rear hatch window?
2. Has this ever gone off on you accidentally, i.e. you are in your house and car's parked in front and you accidentally press the button in your pocket and don't realize you just left your car wide open, or is it a long press/series of presses? Someone on YouTube mentioned accidentally doing that when it was raining. I have never accidentally unlocked my car that way, so am guessing it's not common.
Too bad we can't enable Remote Start on an ORP :(.
It is a double press and hold while windows lower. I don’t see how that could happen accidentally. It does not roll down the rear hatch window.
You cannot roll the windows back up with the fob.
It’s 30 dollars. Just order it and set up all the other configurable options in the first month. Done.
That is crazy. My family business is a garage and part time auto body, i used the autel obd scanner and changed a bunch of things including the windows with the fob and it took aboiut 5 minutes. To charge over $100 is obsurd.
