V6 Valve Job Shop Estimate - Reasonable?
craigfr
After being in the shop for a while the mechanic has determined that the rough idle and lack of power at high rpms is due to a burnt exhaust valve. He said it will cost $2700 to do the whole job incl all parts, gaskets, and labor and will take at least a week. Is this reasonable for a shop visit like this?
He also said I can replace only the three passenger side valves if I want for $700 less, but that as long as everything is out I might as well do them all since the others probably need replacement too. It just seems like a silly amount of money to spend on an engine I thought was bullet proof...
It's a beautiful 2000 SR5 with 202k miles.
After being in the shop for a while the mechanic has determined that the rough idle and lack of power at high rpms is due to a burnt exhaust valve. He said it will cost $2700........yada yada yada
Exactly how sure are you that this diagnosis is correct? Especially with that quoted price.....I smell some pulled wool.
To be honest, I've never pulled a 5VZ, or done anything major mechanical to them. However, I have worked on a lot of 4cyl's, as well as old V8's. I cannot imagine a valve replacment job taking a week. At a shop. Maybe in my garage when I only work on it "after work".
For that price you could drop the pan and install new rod bearings and rings just and freshen her up and get another 200k out of her. I rebuilt my my whole engine from the ground up for less than a grand.
You can get 2 new heads and install them yourself for well under a grand!
^THIS! Seriously, buy some fully reconditioned heads, and do it yourself or take them to a mechanic. Just not that mechanic that quoted you nearly $3 grand for some burnt exhaust valves.
Exactly! For 2700 I will come out to your house and replace the heads with new ones.
$600 is about what a valve adjustment costs on our engines. A valve job is a lot more pricey. It's not common practice to R&R just one head/HG and not the other. So I would confirm that that price is to rebuild both heads with labor included. That job can easily take a week or so because most shops will have to send the heads out to get machined.
Like PitbullRescuer said, you could get a used motor installed with a warranty for a lot less. I would recommend that over a cheap rebuild or just a top-end rebuild.
Do this! Call up LKQ corporation - they probably have a location in your area, and try to find a motor with under 100k. You can purchase a LIFETIME warranty on the engine for an extra charge. I just purchased an LS1 for a customer's Corvette with a lifetime warranty for 3500 dollars! For 2700 bucks you could probably do a 5.3l V8 swap from a newer body style chevy!
