Valvomax?
Jon S
Anyone else use the Valvo max, essentially a quick drain plug?
M12-1.25 Quick Twist Valve with Stainless Drain Tube Knob
– ValvoMax Oil Drain System
Last trips to dealer approaching and tired of them f’ing up my 4Runner, spilled oil, missing, not installing plate bolts, rotating tires when asked not to, losing keys, not checking air filter but saying it’s clean, when I know it’s got leaves in it, general jackassery from a supposed group of professionals.
I can do it, just wondering if this makes it less messy or easier?
Corwin toyota in Boulder is making me grumpy.
If you are doing it yourself, my opinion would be to stick the factory plug with magnet. While it is not a definitive test, checking the plug for excessive metal could be a early warning sign of internal wear issues. Or on the flip side, it is also reassurance that your baby is in good health.
It is not always a good idea to screw stainless steel into regular steel. Stainless can gall. Also, stainless is weaker than regular steel; tighten it a bit too much and it will snap off.
I did my first oil change on my '24 last weekend. Replaced the factory plug with the ValvoMax. First off I discovered that my plug was installed without a crush washer. Also, the factory plug was not magnetic. I'm not worried about not having a magnetic plug, particularly since you can lay eyes on the filter since it's not hidden in a metal can. I also clean my catch pan after every oil change so I can see what, if anything, is coming out of whatever is being drained.. The Valvomax is the first drain device I've ever used so I can't really comment on it yet. In theory I like it but time will tell. I'm not worried about it being SS since you install it once and leave it. It also comes with a crush washer.
I'd be willing to bet the drain plug gasket installed at the factory was stuck to the oil pan. So likely you now have two drain plug gaskets stacked, which will probably start to seep.
Nope, I don't, I looked when it didn't come with the drain plug.
Don't have a Valvomax... but I have a Fumoto that works just fine.
Makes it easy. Saves messing about with the plug. Highly recommended.
Maybe (some day) I will buy the remote (screw on) oil filter kit.
Big thing about the oil change job is dealing with the front skid plate.
Been using the Fumoto valve on all of my Toyotas for 10+ years…zero issues. Using the Femco on the Mustang as Fumoto doesn’t carry a product for the new Coyotes.
I was thinking about buying Fumoto, but my concern is that it is a "moving part" under you car.
I go desert very often and I wonder if dust/sand/mud will have an effect on the valve mechanism...:confused:
My 2006 Tundra went 125k, and my 2016 Runner hit 110k miles with Fumoto valves…no issues with leaks or ball valve. I always check them at oil change time. They could always be cleaned if you found them caked with mud, but they seem to be sealed well.
If you go off road, you should have a quality skid plate. That will protect anything under the engine from getting damaged or too dirty.
I have the OEM TRD skid plate; the only down side of that is it must be removed to change the oil. But there are others that have an access plate to change the oil.
Lots of different types of stainless.
If staying within torque/size limits, breakage shouldn't be an issue.
Always use an antiseize.
Tef-Gel is arguable one of the best for stainless in corrosive and galvanic environments.
If you go off road, you should have a quality skip plate. That will protect anything under the engine from getting damaged or too dirty.
Yes I have full skid plates but desert dust gets everywhere
Let me know the pros and cons of Tef-Gel, thanks. raft wars
Deka
