Very simple lift install question
toyoKühl
Installing my 3 inch OME lift tomorrow morning. Should i install the diff drop before or after? Pics coming in the next couple of days.
Dealers choice. I don't believe that makes much difference. I installed the lift without installing the diff drop without a hitch. Not sure if installing it after would make it any easier?
Just don't remove the lower ball joint no need in removing them just take out the for struts and the use you jack that come with the runner to jack down on the up control arm just place it in the fender wheel once you have it down and room to install the lift you good to go
