Very slight radiator leak
JohnnyReb
Hey guys, I've got a very small leak on the top driver side where the little mounting bracket meets the actual radiator. Is there any steel putty or Goop or anything that could work as a temporary fix?
I would just replace the radiator but cash is tight right now. I just need something to hold in the pressure and keep my coolant from leaking out.
clean it up good with sand paper and alcohol then use some epoxy and get a good bond. Should hold you over for a while.
EnviroHokie
