97BlackAckCL
Elite Member
Arclight boosters back in stock! I just ordered mine.
Triple State Voltage Booster - 5th Gen 4Runner — ArcLightLEDs
Ordered mine, been waiting for a while for them to come available. Thanks for sharing
I won't fit under 4gen's fuse cover. He said that earlier in this thread.
[MENTION=412480]CarlosV[/MENTION] - I have a couple HKB Electronics 'voltage booster' fuses on their way from Australia. Bought them before I knew about the ALVB. I'm planning on using the ALVB today when it comes in the mail. So...I'll have two leftover fuses soon that should work for a 4th Gen. if you're interested. Bought them on June 22, so any day now they should be here.
If you ave ALT-S fuse it will work.
I used to do 1000 miles a week. Now it's more like 10. Haven't had to pull out the charger for mine once in the last 4 months of non-travel, and it's an AGM also.I tend to throw it on the charger every two weeks or so. I tend to notice when it doesn't have the same cranking pep as normal. It is driven daily. Not as bad now that it is warmer.
Are most of ya'll just adding the standard 7.5A fuse to the Arclight unit? I've seen a few folks add a 10A fuse and a few pages back there was a suggestion of adding a much smaller fuse (like a 2 or 2.5 A), to lower the risk in case of a fire resulting from an accident. Yet others who go for the cheaper GM option don't mount a fuse at all. Just trying to understand the pros and cons of a smaller or larger fuse as they relate to safety in this specific use case.
anyone know when arclight will have the VB back in stock? would like to order one instead of the GM diode. Thanks.
