VSC Kicks On When Turning After Upgrade to 33s
lukeskywalker
Has this happened to anyone else after upgrading tires / lift -- the VSC kicks in on the pedal when turning or accelerating quickly on slight turns.
Is there are way to turn this off? I think it's the traction / stability control system not used to the taller tires. Am I correct with this assumption?
Any help would be great. Thanks!
:girl:
I put on 33's, and at 50 mph on Bessemer Mine Rd my VSC light kept coming on. I later reset my yaw rate, have yet to try it out again.
I had 285 toyo tire open country AT3s as a dealership add on when I got mine. Never had to deal with that issue :D
That wouldn't reset VSC parameters.
Thanks Whippersnapper02. Took the 2012 T4R I own to local dealer last week. They did the ZPC, but the problem persists. I read on this forum that there's other calibration that should be done. Appreciate if you have any suggestion, Thank you!
Ambrose67
