VSC trac and VSC off lights - Any fixes?
GCEMSPETE
Junior Member
Hello all,
So yesterday I replaced the water pump, timing belt, and belt drive on my 2004 V8 limited. Everything runs smoothly, no back fires or anything. However, now I have a check engine light on and the VSC trac and VSC off lights are on. I took my vehicle to Advanced Auto and they put the OBD II reader on and it gave codes P0171 and P0174 which translates into Too Lean Bank 1 and Too Lean Bank 2. Any suggestions on how to fix this or is this some sort of computer glitch? Does it have to do with replaced the timing belt? Any help would be greatly appreciated.
Backtrack all your steps , you probably forgot a vacuum line or some part of the intake/throttle body tube isn’t clamped down properly.
2001ATL
