[MENTION=124732]LawnDart[/MENTION] already mentioned your best option, call and verify but I bet you can use the UHWM hidden winch setup without even cutting a slot in the front bumper for the winch line so the only things you would see are your 2 shackles mounts, sounds like exactly what you are looking for.
No one else makes anything cheaper so unless you are friends with a good welder or are one yourself you wont save much if any money by trying to have something custom made.
As has been said, the front recovery/tie downs are fine for most folks and situations but it could be harder to do recoveries/ be recovered without damaging the front bumper skin which is why I assume you want more front mounted shackles. One comment on that, if you are pulling people out of ditches etc.....just turn the truck around and use a rear receiver adapter
If you don't like that option, well might be out of luck and have to live with the stock points. I almost went with a hidden winch mount but saw move value in a slim hybrid bumper for just a few more dollars ......and its a spot to add more lights
