Water leaking in - how to find source?
Metzbower
I have a 2007 T4R that started leaking water on the front passenger side, near the front/hinges. I have never seen the water coming in, but after a hard rain the weathertech mats have about a cup of water on them, and also under them.
I first thought the door seal was out of place and re-seated it, but that did not fix the issue.
Anyone else having a similar problem? I have an aftermarket antenna wire that is on that side for XM radio. I also have a moonroof. If the moonroof drain line clogs up (I am assuming there is one) can it flow into the interior?
Soon to have my wife hold a hose all over the car, starting low to see it that will help pinpoint the leak location.
Thanks for any and all advice!
More than likey its the a/c drain tube backing up into the evap and drain on the floor instead of ground.
matisgugle
