Weird no start issues
Mudballz
Member
2nd time in this year my truck just clicked and no start lock doors set alarm and starts right back up is my battery going bad??:car:
This is not my daily but it does get good runs 2x a week
Mike
Mike
If it starts on second try, I doubt it is the car battery. But you can check the car battery after it rests with a volt meter. If the voltage is less than 12 volts, you may have a bad cell in the battery.
Do you have key start or push button start? If push button start, the battery in the key fob may be going bad (Toyota key fob batteries seem to go bad faster than others).
Also check the car battery terminals for corrosion.
Finally, I wonder is something is going on with the engine immobilizer system. The engine immobilizer system does not allow the car to start if an authorized key is not present. The car reads a chip within the key to see if that key is authorized. The chip in the key does not use the key battery; it works somewhat like the inventory control tags at stores that set off an alarm when you try to exit a store without paying for the item.
Thanks for the replies
I don’t have keyless I will check the health of my battery it’s only 3 years old so I’m asking if others have had similar occurrences
Thanks again
Batteries fail in different ways. Sometimes they just die with no warning, sometimes they give you weight issues. I had a bad battery that would engage my blower on high and I could do nothing to change it until the battery was replaced (in in a 4runner but still).
Testing battery voltage is not necessarily indicative of whether it has issues or not, so don't rely on just doing that at home. The battery may not exhibit issues until it's under load, which is what the parts store will test. I recommend you do that.
i dont believe it is the battery either. good point by previous poster about the how you start it. could be a bad key fob. let us know in an update op
