Welcome to ToyTecLifts.com
I am about to order their 3 inch front coil spacer and rear superflex springs. it is the cheapest and best performance wise lift kit i have been able to find for my 4th gen 4runner. all of their kits look great and they have a very wide selection. Toytec deserves a pat on the back.:awais:
Will this kit work with XREAS???
hey, love the ultimate kit, seriously considering upgrading from my daystar kit
wondering if i could get that discount code?
I have a 2006 4runner limited. I need more ground clearance! Something that raises everything, not just the frame. I do not want anything more than 3". What is the cheapest, highest-quality stuff I should use? I drive a LOT and want them to last. Thanks!
Lift ? 4 Darrick
Darrick, I'm looking at purchasing the 3" Ultimate Spacer Lift for my 2006 4Runner. I was wondering if I also need to install the rear spacer that comes with it? All I want to do is lift the front 3" to even it out with back.
Thanks.
If you want to do it, and do it right, our Ultimate Kit is what you would want!
Life time warranty, closest to stock ride quality.
http://www.toyteclifts.com/index.ph...ategory_id=72&option=com_virtuemart&Itemid=72
Still planning on buying a lift from you guys down the line, couple questions,
What does the lifetime warranty cover for the ultimate kit?
Also what kind of warranty does the OME kit have?
Does the ultimate lift provide more lift then the OME?
I'm in the same boat
you got one too! :runaway:
I'm in the same boat, I have a 06 Sport, 4wd, V6, sounds like X-reas came standard on them. Which lift works best with this system and do you recommend a pro installs this or can a do it yourself install it when dealing with the X system?
Thanks,
JT
Got home from dinner to find my Toytec box on the front step! 3" front 1.5" rear. Was hoping for a sticker in the box too, but no such luck. I guess I'll keep it. HA
Yes, the warranty does cover the Ultimate Kit.
the OME carries a 2 year limited warranty.
they both can reach 3 inches, but the Toytec Coil Over can reach 3.5 inches.
sorry for the delay.
also if u choose 3.5'' with the ultimate up front it will be kinda stiff so get the ultimate and crank em to 3'' only and you'll get an amazing ride :) just my .02
Thanks,
JT
Our spacer kit, or just a front coil is will work with your suspension. If you want to replace the shocks, that's when you will have to get rid of the x-reas suspension. THIS is a great option.
alsayner
