Well I managed to warp my Tundra brakes...
twitchee2
Member
So i was coming down the hill from tahoe and once the brakes got good and hot. Once that was the case, the were shacking the whole truck. After i was able to cruise on the hwy for a while it did not shake. Im not 100% positive that it is coming from the front but im not sure. So i think i need to take them in and get turned and hopefully they are good to go.
how on earht did you ever get them that hot? hwy 80 or 50? and where at? ive towed a 15000lb trailer down 80 with a older 1ton diesel ford and never got the brakes hot enough to shake the truck(i found out later my brake controller for the trailer wasnt working). and ive towed my 85 pickup down 50 with a friends runner with the 199 brakes and never had issues, you must of been hauling butt
Actually coming down 20 through grass valley. But i originally felt them warp going down kanan though the mountains down to malibu. Iunno what i did to cause it other then my rear breaks were not properly adjusted.
wow apparently not, thats crazy but i think you will be fine, just get your rear brakes dialed in so they are working properly and you probably wont ever notice it again.
thats the thing, i did get them dialed in properly after the i first noticed it. then it happened again. thats how i got to the conclusion i need to get them turned.
