BoulderT4R
Member
We’re shopping new tires for our ‘24 TRD Pro that has the Westcott lift installed (with OEM Nitto tires).
We’re looking to go bigger on the tires and I’m debating 285/70 or 255/85.
There’s tons of info available on the 285s but less so on the 255s. Is anyone here running 255/85 with a similar suspension lift? How is tire clearance? Any modifications needed?
I’m interested in the 255 because they are sized for the TRD Pro wheels (7”). I know a lot of people will say 285s can fit 7” wheels, but I’m more risk adverse and would prefer to stay within spec.
I’ve also heard the 255s will handle better on road, and specifically on our wet PNW roads.
Reading things online it sounds like the 285s typically fit the Westcott lift without much, if any , trimming needed.
The 255s are quite a bit skinnier but they are also taller. I’m not sure if that increased height is going to cause more rubbing and require more extensive modification.
