Moved my CB antenna to the CBI rear bumper. I believe the existing bracket/hole was for the additional camping light. I now don't have as much nervousness about damaging the hatch panel. I pretty much gutted my diamond K400 mount and everything worked great.
Here was the old setup. I liked it but thought I'd try something different!
i love my 5th gen trd pro but i need help
About two months ago i ordered and installed, on my 2016 trdpro 4runner, the JBA long tube headers, urd rear o2 sim, urd y-pipe, and urd high tuck exhaust. After the install i had a cel, which turned out to be p0130, bank 1 sensor 1 circuit malfunction. I ordered a new denso 02 and installed it. After install, it still threw the same code. I swapped both banks #1 sensors to make sure that the new 02 was not a bad unit from denso. The code stayed bank 1 sensor 1. I tightened the header flange bolts and it seemed to keep the code off for longer but it still came back. i plugged the exhaust tip and found a leak on the header flange. I took the headers off and hand filed the flange sealing surface until it was straight, but i had to use the oem gasket as the JBA gasket was fubar. AT this time i also changed the spark plugs just in case. The code stayed off a little longer but it eventually came back. Finally I ordered some percy's xx-carbon gasket material, cut a new gasket, refiled the header sealing surface again, and reinstalled everything. I haven't found a leak yet, but the code came back on. The weird part is that the code only comes back after the engine is to full temp, and you coast down a long hill, (ie: engine braking). You can clear the code and it comes right back still but always when coasting downhill, in gear. P0130 is the only code that t throws. The yota still runs fine but im tired of the light, and safe mode gas mileage.
Haven't done much or posted here lately so kind of a update dump
Made mounts for my traction boards to mount to my factory crossbars sometime during the week. Ended up bending up some 1/8" aluminum to make the mounts originally planned on u-bolts with a plate that idea ended up not working.
Saturday picked up a TRD skid from Lucky Lou super nice guy. Installed it around midnight took maybe 10 minutes tapped all the holes and used anti seize so I shouldn't run into any issues down the road.
Finished off with some range therapy on Sunday had somebody tell me sweet jeep.... It's a subaru crosstrek actually :peep:
Nice pics! Is that Texas Canyon? I live in SCV. We should go wheeling sometime!
No in front of desert marksmen right off of Angeles forest highway, close tho! But I'm down I usually wheel/ride the Bouquet canyon side of Texas canyon up to the lookout always either in my 4runner or on my 500. I'll PM you my number maybe we can meet up sometime
Not today, but Saturday. Went from this:
To this:
Added Bilstein 5100s all around, Wheelers off-road T1 and T13, SPC UCAs, FN Fx Pros, and Falken Wildpeaks 285s. Absolutely love it.
Sent from my iPhone using Tapatalk Pro
...But won't that extra sticking out help prevent door dings from inconsiderate buttheads when ya park?...( they don't look like they stick out as much as the standard OEM running-boards? )...
Yes that's the only reason they're still on there lol. I think they actually stick out more than the OEM steps did.
First time putting a trailer behind one two, had it all sorted.
hows the output? And please don't post a pic of the light turned on at night facing the camera. does no good for anyone lol.
the pricing is pretty good and its Morimoto :bigok:
I've never had a light bar before so can't really comment but it's bright lol I will post an output picture tonight. Sucks though TRS no longer sells the yellow inserts.
i saw they didn't have that option anymore. Some yellow laminex or whatever it is people use on their fogs would probably work.
