some trip amenities showed up just in time for the weekend
Installed some Rigid dually midnight edition and connected them to the oem fog light switches. Opted for the non SAEs since the plan is to only use these on the trails. My only gripe is how it doesn't sit flush to the oem bezels. The light output though is amazing.
Drank the Kool-Aid and bought a Pedal Commander. Figured with the Bluetooth I could opt for a more discrete mounting location. Found a switch blank in the back of the glove box that I was able to route the cable through, across the center section and down to the Pedal [emoji1360]
City +2 is a whole new world. Playing on Sport was pretty fun too.
The regular pedal commander comes with bluetooth or is this a different model you ordered?
Nowhere near in comparison as to just pushing the gas pedal further. It has a quicker response. Just get one. You'll love it.
Yeah I will have to wait for a sale and just continue saving up for this one. Can't justify the funds right now. But everyone that has one says it works so I'm adding it to the list. Ahh, the ever expanding list. :dancin:
It definitely has improved throttle response and more get up, I'm not sure if it's from the airflow accelerator, resetting the ECU, or the new battery, or a combination of all of them. The battery sure improved the ignition startups to fire immediately when the key is turned. The butt dyno definitely has more get up and go though, so I'm happy
Cool! I wanted to say i felt the same improvements. My 4runner SEEMS to climb the same hill with less effort. No improvements on mpg at all though. I'll have to pair this w/ a urd maf calibrator to see if it helps.
As far as battery. I'll put my vehicles on a battery tender overnight every other month. After each session, i can totally tell the engine starts stronger and easier.
Had to redo my Pro grill install because the left side just wouldn’t go further back anymore and the white body was visible by the tabs. Took the grill off, hair dryer and a lot of force got it fixed up.
did you have to reapply tape? I need to redo mine as well... botched my install
Oh my... I have a serious camp coffee thing. What is this and how do you like it? Seriously, I need details.
It's the Wacaco Nanopresso with the add on "barista kit". The kit comes with a larger basket and water tank. The Nanopresso runs at 18 bars / 260+ psi
Way better than the handpresso at 16 bars. Hell, I'd venture to say it pours a better cup than most home espresso machines. Highly recommend this little guy.
No I didn't. Hair dryer on hot for a few minutes, apply pressure then hair dryer on cold. When I put the grill back on I just didn't force it past the tabs so now it looks perfect.
Got 2+ years and 40k out of the OEM wiper blades. About 6 months ago had to replace quickly with some Rain-x blades because of a tear. Now after 6 months they are starting to streak. Doing it right this time and for half the price. Ordered two sets of OEM inserts (planned on doing this the 1st time so I kept the OEM wipers). As [MENTION=65614]Antman[/MENTION] promised, less than 10 minutes, even for me. Now i should be covered wiper wise until 100k.
FYI I got each wiper insert for $7.50 a piece from Toyota Overstock plus shipping.
http://www.toyota-4runner.org/5th-gen-t4rs/159983-%2A%2Ahow-change-5th-gen-factory-wiper-blade-inserts-pictorial.html
I added this massive thing to my 18 limited. I have retained almost everything when using the idatalink maestro.
Sent from my Pixel 2 XL using Tapatalk
oh nice! is the position fixed or can you move it around? such as tilting it up down left right or if it sits to low can you move it up a bit or vise versa?
It can be moved around during set up but remains fixed once the screws are fastened.
Cpn2mss
