Thanks for the work on my new UCAs, Toyota:
Passenger side
Driver side
Built this for an upcoming 2 weeker in Utah. Finishing touches coming this week/weekend.
Sent from my Galaxy S7 Edge using the Tapatalk app.
Ocala National Forest today. Found enough trails and wash outs to have a little fun. Saw the Navy A10 Warthogs make a strafing run on the bombing range. Can't see the targets but it's cool stuff anyway. Also saw a Juvenile Black Bear. And no I couldn't get a pic because we all surprised each other and he did 4.0 flat 40 on out of there.
I like!
I also want to put a cargo box beneath one of these, could you measure how much space there is from the bottom of the rack to the deck of the cargo area? Hopefully 13 or more inches?
Thanks,
I wont be installing until this weekend but I will measure if you haven't gotten your answer before then. I have 3rd row though so you'll have add about 5" to whatever measurement I have...
Yakima Megawarrior Delete
I removed my Yakima Megawarrior, Corebars, and Timberline towers due to the howling at 60+ mph. For the cost of the system, I could have a Gobi instead which would be more aero, quieter, and look better.
While I like the Gobi Stealth, I'm considering a custom build tailored to my needs. The accessory mounts look wonky and I'm not sure I'd trust my bike racks & bikes to them.
you digging them? Feels a bit heavy so I'll see once I get it painted and installed
Despite signing up for the group buy I wasn't alerted to the group buy process.
So I missed out. I find that my goose gear setup holds all the stuff I want, and I like having those windows be unobstructed. I really like the concept of these, but I'm a tad afraid of putting anything beyond light pouches on them due to the fear of turning gear into missiles in case of a crash.
Installed Billies on the front. Set at 1.75" (3rd notch). Leveled the truck out nicely. $210 with shipping on Amazon, installed them myself which only took 2 hours, then $80 for an alignment.
Used the non-spring-compressor method. For those interested:
-jack front end up on stands
-undo front bumper cover/skid plate to have better assess to LCA cam/bolts
-remove tire
-take note of spring orientation (I took a picture for reference)
-place stand on rear frame opposite the tire you are working on
-jack up LCA to apply pressure to strut
-undo strut retainer on top of strut
-undo lower ball joint bolts (2)
-Mark position of LCA alignment cams
-loosen LCA bolts
-allow pressure out of jack so spring decompresses (carefully)
-remove lower strut bolt
-remove strut/coil out of the bottom
-assemble and install new strut replicating spring location and orientation that was previously on the truck
-do all of above steps in reverse to reassemble
-**apply red LocTite or equivalent to lower ball joint bolts when putting everything back together**
-go get alignment
I was skeptical about this method. When I let the pressure out of the jack holding up the loaded piston I was actually hiding behind my garbage can in case something went horrible wrong. But everything went amazingly smooth. The only snafu I had was when I was trying to giggle the LCA down, my had was grabbing the UCA and the spring came unseated and jammed my finger between it and the UCA. Other than that, happy with my now leveled out T4R.
I think they are a great idea, if just to keep the dog from licking the window. :biggrin1:
How much do they each weigh? It would seem something as heavy as steel in an application such as this would out of the question for me too personally. I have the same thought about in cabin projectiles, if it did break loose I would want it to flex or fail on impact instead of lacerating anything it came in contact with.
It would be great to see one either thermo molded or waterjet cut from some carbon fiber reinforced plastic type material.
if you do decide you want to order, the GB turned into a discount code found on page 1 of that thread, and is extended thru the end of September, code is: evan
youngrk
