Just so you know... you can get "cassettes" on Amazon that plug into your phone. You put them in your cassette deck and you can play what's on your phone. $20.
Yea, I tried one of those. Only worked for about 3 weeks, and the sound quality was really bad. When it stopped working, I took it apart, I think the shitty coating on the magnetic array plus the fact that you can't stop the head on my oem tape drive really accelerated its demise.
Put in a new head unit w Bluetooth & Sirius and ditched the power antenna for a taco whip.
Also, thanks to whoever it was that suggested tying a string to the old antenna cord and using it to feed the new one back through to the console. Genius idea.
Today/past couple weeks.
Moved A/C controls
10.1” touch screen Android head unit and backup camera
Panavise phone mount bracket and gravity wireless charger
Swapped the cigarette lighter for dual USB port with voltmeter
Chopped down the shifter height
TRD shift knob
Moved A/C controls
TRD shift knob
https://i.imgur.com/7vqt5k6.jpg[/MG][/QUOTE]
Oh man I'm getting screen envy. My 7" touchscreen just seems inadequate now...
Damn. Does that detach? I’d be paranoid as hell leaving that visible in this truck.
It does. The height is adjustable up and down, as well as rotates side to side. So to take it off you can just slide it up and off and then disconnects with one connector.
I don’t park anywhere sketchy so I’m not too paranoid. Usually just work and home. But if I do, it would be easy to take off in a matter of seconds.
That's exactly what i was planning to do for a few years now! just havent pulled the trigger. so glad this worked out for you and it looks good! i can now buy an android unit and mod my center vac controls with confidence. might hit you up on the deets soon =P
And you have a 2002 so yours should be a little easier since I believe your controls are all done electronically. No manual cables.
Moved A/C controls
TRD shift knob
why do you have a phone mount as I'm assuming you can access your phone through that amazing stereo?
For charging and keeping out of the way.
There are still a few things that can’t be accessed through my phone.
Since the radio is android and I have an iPhone, they don’t play nice together. The Bluetooth dialer kind of sucks through the radio. I would have to manually enter all my contacts since the iPhone doesn’t store contacts to the sim. So it’s actually easier to access the contact through the phone. It will then make the call over the Bluetooth.
Also for texting as well. If you have an android phone, there is an app that will display it on the radio as a notification, but doesn’t work with iPhone.
Did a bit of body work yesterday and pulled the right fender and grille off. Gonna go visit a scrapyard today and see if I can find any goodies.
Did you cut off the retainers and ABS ring?
No, I was able to pull them off intact using a bearing separator and a press.
I reused the ABS rings, though I got two new inner retainers for the seals. I know folks have swapped inner and outer retainers, but I decided to get two new inner ones just in case, and reused the two outers.
I used to have that tape measure. It grew legs though, and has been MIA for years.
Don't forget a new breather, though you may have already done such.
I think those were best tape measures ever made, I couldn't believe it when Stanley stopped making them. All of mine slowly disappeared or broke, but one day I saw an Ebay listing for six new ones. I bought all six :).
I did the breather extension while I was waiting for the axle parts :). My original breather was not clogged, so I don't think that it was much of a contributor to the blown seals. Interestingly, when I took apart the driver side axle (the one that was not yet leaking externally), I found lots of diff fluid in the cavity, so it was on its way out.
I made the mistake of ordering two rear axle kits from Marlin Crawler, thinking it would be one convenient bundle. Unfortunately the most critical parts of the kit, the seals, were not Toyota, and not the new and improved design. So I was not going to use those kits, and had to scrounge for new parts at the last minute. Hence the one week downtime. But I'm on the road again now, yay!
Trying to return those kits is going to be fun, Marlin Crawler does not pick up the phone or reply to emails.
Replaced my long overdue valve cover gaskets. Did spark plugs while I was in there. No more burning smell from oil dripping on the exhaust manifold!
Philthyphilthy
