$1,699 all in with the triple stick setup now
Sent from my Pixel 4 XL using Tapatalk
Look again, that doesn't include the triple stick shifter kit, that's $549.
There's a note on the Ecocrawler kit that says you'll need to use a stock shifter unless you get their kit (which would involve another hole in the tunnel 6 inches back, I guess).
Is the top shift interface "ball type" or "spade type"?
Ah nuts
Summer gear set sale at Yotamasters
Got me a set of 4.88s!
$884.88 including tax and shipping for Revolution gear set (4.56, 4.88, 5.29) including Toyota ring gear bolts (10 per gear) with a 10% discount automatically applied
I added 5 bolt retainers to my cart, manually, they are not included in the kit, but the price above is for the complete cart, tax with free shipping
II got the 'spade type'. I think that is the kind that works with their shifter kit(?), and the ball type would work if you were going to bolt a regular shift lever to it?
I'd certainly talk to NWF about if though, if you were thinking about ordering.
The triple stick kit costs more than others (my wife got a Radesigns kit for hers), but it's a very nicely made shifter, big chunk of aluminum and big solid pivots for the side sticks that won't buzz or rattle.
P0240
I took a video, I'll get home and get it on here later, thanks for your reply
A 240 or a 420? A 240 would be an odd code for a 4Runner to throw, it seems to be related to a boost pressure sensor reading. A 420 indicates the ECU sees problems from the second 02 sensor, which could indicate issues with the cat (or the sensor).
You have a choice, either or
I contacted NWF and if using a VF2 transfer case as the donor for the crawl box you need top shift spade type.
EDIT: This is with or without their triple shifters. (VF Transfer Case Top Shift Offset for the triple shifters.)
I'm going through the brain card catalog (am old) and can't remember for anything who here has a blue and white motorbike that might've been on Engineer pass 7/28...
Also, did some bumpity bump. Now doing a little fixity fix.
Since my sunroof won’t open, how do i get it to open?
You can remove the entire sunroof by removing the 4 nuts that hold it in. There are hidden plastic trims you need to remove first in order to access them. Not sure why these sunroofs don't like to open as they get up in age (mine doesn't open too). I'm sure most 3rd gens on the road today have sunroofs that are non-functional.
The sunroofs are actuated (between the motor and the panel itself) by plastic coated steel cables that slide in grooves in the aluminum sunroof frame. By necessity, those grooves are open on the top, so the brackets that the sunroof panel is attached to can move back and forth.
So over time, dust and grit gets into those channels through normal use, and wear happens on the plastic coating, through sliding back and forth. And moisture gets the steel to rust, which expands and makes the cables stiffen up in the channels, and eventually seizes the roof in place when the motor can no long budge it.
If you can get it to budge and open, you can try cleaning/greasing those cables and getting them back into action with the sunroof still in the car. Try gently pushing down on the back edge of the roof as you try to open it, or try pushing gently up on the back as you try to get it in 'vent' position. Try going back and forth.
But if it's been stuck for a while, it's probably not going to free up doing that, and the alternative is taking the entire headliner out, and then removing the sunroof assembly and taking it apart to replace the cables. They do sell new replacements, but after watching my wife do this on her '96, I can say it's some very finicky and tedious work.
Mine seized up earlier this year after I hadn't used it for a while, but I was able to coax it back into moving, and then spent a while trying to clean and grease it, and it's back into normal function. I just try to remember to use it frequently. Pop it into vent mode, open it, close it. Far more likely for it to stick again than it is for me to wear anything out on it.
My fear is that mine will get stuck open. Is that a thing? It tries but doesn't fully move on its own currently. I have never opened it. I have siliconed it to reduce rain leakage. I guess I should have bought a full length rack to keep it dry....
Philthyphilthy
