installed my ultra gauge.
Found a guy parting out a 00 local so I grabbed the center console so I can finally have a cup holder worth using.
Got the whole console, ebrake, and bracket for $40
Everything was bolt on, just have to trim the lower plastic for the shifter trim.
I replaced my OME 891 coils with LC 8 wraps. For now I'll keep the OME 60027 shocks in. It's hard to tell from the picture, but it has quite a bit of rake with the OME 883s up front. I may remove the cones to reduce the rake some.
Replaced the Front Differential fluid with synthetic... couldn't get the drain plug out (as so many others have found), so I just pumped out what I could, added a small amount of new, pumped that out, and repeated until the stuff coming out wasn't black. Then added the required 1.2 qt and am assuming that if I overfilled, the extra will come out the breather.
I gotta say though, old gear oil smells terrible - what's up with that?!
I also topped off the radiator and tightened my alternator belt. Waiting for warm weather and copious amounts of free time to put in a new rad, replace the belts (accessory and timing belt), and water pump.
Might just take on the transmission oil this evening... if I'm feeling motivated.
Did you have to buy the mounting hardware or did it come with your new bumper? and if you had to buy the mounts, where did you get them from? I got a TJM bumper and am looking for new mounts bc mine are bent.
pax at 4
