FINALLY swapped out my busted up catalytic converter!!
:cheers:
It was a huge pia, but hopefully now I can pass emissions and get some of those mpgs back. Can't tell you how happy I am to finally have that finished...it's been an ongoing issue for at least a year!
Alaska to Florida?! You're doing it wrong! Haha, just kidding. I mean, Alaska seems like a better fit for me, but I also don't like heat. Good looking truck btw!
What did you replace it with? I am probably going to need a new cat next year.
@ shadow247
I replaced with a re-certified used CC from a place called Recatalitico. I assume they have some sort of scrap yard where they pull these things from, test them to verify they still work, then sell them to suckers like me. I figure that the chance for long-term success is about as good as with any after-market cat and this was cheaper (for both CCs). It has a decent amount of surface rust (not much worse than the one I took off though), but the engine seems to be breathing a bit easier - from what I could tell on my 15 minute drive into work. Hope it lasts!
Yesterday, my buddy Matt and I changed the struts/shocks on the t4r... changed the oil too since we were under there and it was just about time anyways
Changed my oil today and tried the funnel method to catch the oil from the filter. I think it was BTO who mentioned this but not sure. Well, it still spilled some but not as much. I guess there's no way to do it without making a mess...
While I was down there I noticed the second rib on my inner cv boots was rubbing a nice groove into the first rib. Spread the inner boots out so now there's space between the ribs and used a size 16 38mm hose clamp.
Haha my brother was under the car with me when I was taking out the bolt for the oil, and it sprayed all over his coat.
Why has no one invented an oil plug that comes out clean!?
put the last coats of paint on my new to me bud built. should have it installed by friday afternoon. considering i got it from [MENTION=8883]LINY4Runner[/MENTION], it needed some work...
Ground down my sliders and skids from those pesky granite rocks out in Texas and gave them a fresh coat of paint.
Looks like I drove over a giant metal cheese grater on both sides of the truck.
20130320_180007_zps5de81932.jpg~original
Got the new rad in last night. Turns out the mounts were bent on the support so I had to shim it up with washers in one corner. doh. It'll be nice not to have to top it up all the time now!
FAK!!! why did i ever lift it :redbrick:
fak038_zpsf3ef49e2.jpg~original
question for anyone who can help me. I'll do my extensive search after i post this but yeah
- as my daily driver, should i fix this ASAP or can i order my coilovers then fix it?
- Will coilovers keep this from happening again?
- does my diff drop just suck balls?
- the inside boot is the one that is torn i guess i gotta take it all out? this sucks ballz dammit!
No big...
I just did the left side in my truck. 175 $$$ , 35 minutes and it was done. Easy! The core was almost as much as the part it's self. Mine had that shit all over the truck, I'm still trying to get it all off.
Blue
Removed Skids Plates, Cleaned all the grease off them from the axle that went to shit. Going to repaint them and re-install. Also, new wheel caps came in today so they will be painted at the same time too.
:heh:
increasedc
