Finally did Timing belt, and other stuff.
Finally found the time, and a long enough stretch of good weather to do the Timing belt project on my '03 Limited. I knew going in, it was going to be a bit of a PITA because of the age and miles on the beast. Probably why I kept putting if off. It has 284,000k on her, and because I am the 2nd owner, the actually time/miles it was last done is somewhat vague. The PO didn't keep accurate records, and not all work was done at a dealership. So, I was pretty sure it was LONG overdue. But, since I have to do the work outside, I had to wait for the right opportunity. I had ordered a timing belt kit from an ebay seller, over a year ago, so it had been a while waiting on the ideal time.
I won't bore anyone with all the gory details, but to say it took me over a three day period to finish the job. Because of other problems to deal with, I was only able to work 5-6 hours a day on the job. That, and problems with rusty bolts/nuts, and other problems that cropped up, it took a lot longer than I originally thought it should have. I don't remember who originally posted the suggestion, but I found that using an old serpentine belt to 'lock' the crank pulley in place while loosening and then tightening the crank pulley and cam pulley bolts worked amazingly well, and made that part of the job a lot easier than I expected.
The biggest unexpected problem was the alternator. When I unbolted it to gain access to the water pump and belt tensioner assy., I left the wiring attached, and just moved it to the side, out of the way. When it came time to re-attach it, if found that the ground cable connector had corroded through and broken loose. The stud on the alternator was so badly corroded, I couldn't re-attach a terminal to it. So, thanks to NAPA, I now have a 'new' remanufactured alternator. In a way, it was a good thing it broke when it did. If that cable had come loose on the road, I would probably have been stuck in a bad way.
So, after many issues to fix/solve, I finally got it all together, and it started right up. The old timing belt was still working, but it had many small cracks on the back side surface, so it was definitely over due to be changed.
I'm not as young as I once was, and my back is not happy with what I put it through the last three days, but now I get to relax it for a while. :cheers:
The 2008 - handwash, claybar, DA orbital polish using Meguiars kit that goes onto your own drill and Meguiars Ultimate Compound.
DA polish brought out more dirt after the claybar treatment. Wiping off the Ultimate Compound the towels were dirty after wiping off small sections. It sure did bring out the shine. The truck is silver so swirls were hard to spot but on darker colors a DA polish really cleans up the clearcoat.
Finished up with a coat of Meguiars NXT Tech Wax 2.0. It looked OK before, but now the shine really pops.
I am far from an expert, but in my opinion, if you are bringing out dirt with the polish, you are scratching your paint.
More importantly, no pictures????
Niagara Falls bound...............
Doing a 7 hour road trip with the fam. With a 5 year old and 19 month old, not having a fully functional DVD system is just begging for WWIII.
Anyway, DVD player died on me a couple of years ago. Had the company send me another one (reman........ I didn't care, as long as it worked). Haven't had the time when it came in a couple of years ago and completely forgot about it. Anyway, installed the "new" unit and so my little ones are ready.
Rosens AV7900 . Touch Screen easily pops off with a special tool.
65FD5A42-7DBE-4F94-9332-3FAD3FD66335_zpskqc8qegj.jpg~original
Completely forgot the old unit wasn't in there.
FD4B1F36-F82A-430A-8330-B8787880B6F2_zpsub64b78u.jpg~original
Plug in harness and pop screen back in.
F911737D-1371-4C71-A10D-64E98747C433_zpscxaxiwua.jpg~original
Princess movies!! ( for you parents out there, this is freeking GOLD. Beats having them get bored........ and crying, nagging.. etc etc)
FF3E1DC5-6628-4B2F-87A6-CBDDAC5EFF65_zpszlakekhf.jpg~original
I polished the clearcoat, didn't get near the paint. What I did was finely grind off some of the clearcoat with a polishing compound, a low grit polishing compound. It's a well known procedure. The 'dirt' aspect is because over time the clearcoat gets tiny scratches in it which holds fine particles of dirt - dust really. That dulls the clearcoat.
It's not a procedure you do every year, it's a one time procedure you do to restore 10 yr old clearcoat to showroom shine. Then you have to keep it waxed because another DA polish can wear through the clearcoat to the paint.
Pictures? Sorry, I didn't do a before/after and with silver paint one wouldn't be able to see the difference in a picture. With a dark color a picture would show that the difference is striking.
Beauty
Not today, but last weekend. Haven't had time to post, but went fly fishing on the Big Thompson. I'll take it as a win. I caught 4, wife caught 0. Ha. But she looks damn sexy!
So does my wife! :girl:
Took off the factory sport bars. Which are free for the picking up. And cleaned and painted it. Sliders are going on next week. My kid will be pissed for a week.
Yesterday I took my bumper off and added the trailer plug as well as an actual lit license plate bracket. While it was off I sanded and repainted it all as well.
Will get more pictures when I reassemble today
When you replaced the Pulse Regulator, did you have to relieve the fuel pressure or did you just wrench it off and wrench the new one on?
Just wrenched it..Wait until the engine is cool to do it. if your worried you can pop the gas cap off but shouldn't have to when its cool. A few drips will come out you can shove a rag in there to soak up.. most important is not to lose the tiny washer that comes off the original an put it back on the new one.
Went to the Krawlin for Cops event at Rausch creek PA. Ran blues and Blacks. Went up there with my buddy who is NYPD Swat and his lifted 07 tahoe ltz.
'08 out of the garage, '07 in to get it fixed up to donate it to souldog.org so they can put it to good use doing rescues in remote areas. Only 113k miles on it so it should be good for a lot of rescues.
finally got my cvj cv axles installed. they were a much needed upgrade before the season starts. first one was a pia to get out, since it doesnt just "pull" out as most write ups/videos explain. def couldnt have done it without a heavy duty crow bar. now just waiting on the gates to open in colorado...
Sent from my SAMSUNG-SM-G920A using Tapatalk
Tx470
