diy budget bluetooth install. might put it under the console or something later but for now this will do
and found a better spot for the xgrip mount
I just ordered a similar one the other day. How do you like it so far? Do you need to turn it on every time you get in if it is constantly plugged in like that?
i keep the inverter on at all times so it hooks up when the truck is started. i will at some point hide the unit so it can not be seen
[MENTION=87687]LTDSC[/MENTION] inspired me to paint my fenders today. Picked up some duplicolor color matched paint at autozone. Turned out pretty good I think, and matches. Got some orange peel, but should be able to take care of that with some sanding and polishing.
Ps. Don't mind my muddy ass truck. Had some fun last night
dont think you can paint match dirt :lookout:
Looks great! You clear it? Wet sanding and polishing helped my clear smooth out and be like butter. Love it! You're lucky it matches so easy
Haha, Ill wash my truck tomorrow, but Im sure by next weekend itll be back to dirt camo
Thanks, and yes I did. Used some duplicolor clear shot out of a harborfreight spray gun. Worked real good for $10, and made it a ton easier to get an even coat.
Finally got the CB installed, its only a handheld unit and the mount for it was missing some screws so the cupholder is its new home. Do you guys only use it on the trails, if you use it at other times what channel/s do you use?
Only other time I use it is if I'm driving with friends who have them, or if I'm on the highway and then I usually just stick to channel 19
Finally got around to installing a 1/2" body lift. Only took about 2.5hrs start to finish and everything went pretty smooth. My only concern is that rear bolts are not showing much thread. Does anyone know the specs for these bolts? I'm thinking about just ordering a couple longer ones just to be safe.
New exhasut today, thank you sodium chloride! Pipe before the muffler, new muffler, plus the elbows on each end. Chopped out the rear resonator and bending the tailpipe to the side while they're under there.
Sounds good now, a bit louder under throttle but a very nice tone. Gone, of course, is the ugly, broken exhaust noise from before.
delislerebecca
