i simply dont understand how someone could do so many swaps and everyone be cool with that LED not getting swapped as well?! It drives me nuts on my own truck, but i know i have no one to blame but myself!! one of these weekends i'll tear into it and figure out how to swap it. i'll pm y'all when i do in case y'all want yours swapped...i'll make y'all a killer deal!!
He also made me drive around with no HVAC controls in the middle of winter for over a month, when I specifically scheduled time (a week and a half) with him that the truck wouldn't be driven. Your service is leaps and bounds ahead, you shipped my steering wheel controls back the very next day :cheers:
What material did you use to make the new fairing? I would like to make an extended fairing for my Load Warrior.
I used Plexy glass, But get the stronger stuff it's more expensive but worth it. I think i paid $67 for a 36x48 sheet vs the regular plexy that was around $30 and i broke it in 2 seconds at my first couple of attempts doing this. Then i used a dremel to shape it and vinyl wrapped it..
After punching a hole in the secondary oil pan last summer, I finally ordered, painted, and installed a new RCI skid plate. It is my wifes car she requested it be matched to our bike rack, so it's orange.
Swanny let's see some photos of the entire rig all put together and painted! The skids look like they're bronze so now I'm hankering to see the ski rack AND the skids...if possible. Nice work!
Can you put that rubber grommet on first, then put the ballast through it? This would provide the seal you need, and still get it hooked up.
Well, I might be able to get the connector on there with the outer headlight grommet in place, but there's no way to get the one on the connector harness to seal inside the outer grommet, thanks to the 90 degree bend on the connector.
I figured I wasn't the first to encounter this issue, and sure enough, I may have found a solution. [MENTION=50591]gaterose[/MENTION] had the same problem in his initial post here:
Mini Morimoto RetroQuik Bi-Xenon Projector Swap for '06+ Headlamps
I will probably follow his solution and swap out the D2S ballasts for AMP ballasts, and use straight AMP to D2S adaptors. I'll still have to seal the back somehow, but at least there won't be a right-angle bend to get in the way.
If you can find a grommet like the grommet that comes installed on the D2S plug it will fit snuggly into the OEM grommet on the headlight as well as over the D2S straight connector wiring. I cut mine off and used it but they charged me a fee, it'd be better to just see if they can ship you one of those grommets.
Finally installed the smokers kit. I still plan on transforming my center console from a 05 to an 08+, until then, this will do.
Before:
524C99BD-90C1-4BA5-8FCE-E3EF6034D38F_zpsalhaicb9.jpg~original
After:
A4DDAE31-AE6A-4531-985C-CBD5A38F7C2E_zpsecfoltts.jpg~original
Night shot: lights up (posted this b/c I've never seen the kit lit up)
D070D451-D29A-4B45-86A9-BF653A8E3C0B_zpsu9pzgcbg.jpg~original
There's also a small light when you open the trap door (where the ashes go).
Like so:
C2A9CDA2-000B-427D-A4CF-54896055D24C_zpsckl9bxzu.jpg~original
ALSO, washed her to get all the salt crud off:
0EB2B172-3FF4-4BDE-B329-F66687BB43EF_zpssuaczkhw.jpg~original
its good to see someone is trying to make it work. the 08 panel looks the best in my opinion
Had a busy weekend getting the truck cleaned up. Decided to stop on the way home from work and snap a couple of pictures since I hadn't updated my build thread in a while.
Its not really what I did so much as what I PURCHASED for the 4runner.
All-pro Uniball UCA (500$)
Uniden 510xl CB with mic and speaker (25$, yet to see if it works, but according to the guy its should)
3 foot CB antenna with magnetic base (20$)
Spider trax 1.25" spacers not shown (180$)
Sorry for the bad pic.
my setup is about the same. uniden pc33x and a k30. as a plus my cb was free and it came out of our old 1st gen
IMG_20150301_145045_zpsfff6ac5b.jpg~original
IMG_20140830_121135_zpscc40432d.jpg~original
Awesome! Free is even better lol Do you find the position of your cb impeding the movement forward/backward on your seat at all? Not sure where I want to place mine yet, was thinking under the arm rest.
im tall so my seat is all the way back. i used velcro so if i need to move it i can
Hit 200k a few days ago. Ordered a flowmaster 44 and a kenwood touchscreen as her present.
