I'm having this debate right now - Icon extended travel doesn't give any lift so I'd have to get all my lift from preload (3" max)... worried it'll be a really stiff ride...
but radflo has a 2.5" lift with a ton of adjustability...
Go with King springs to get more lift
Did you figure out what this ticking is?
Yeah it was me just being paranoid about my motor. I recently switched to synthetic and that coinciding with the cold weather was just making the standard Toyota sound. My apologies for the delay but we compared the "noise" to several other similar motors and it was just the noise the motor makes. No misfire, sticking lifter, or anything. Just the little motor firing away.
RadFlo also leaks a ton. or at least reported a LOT of leaking.
programed new key fobs and a transponder key
Got the key fob (HYQ12BAN) for 19.99 off ebay looks almost new!
key was 8.00
had to clear all the FOB codes because it was maxed out at four codes programed and we only got 1 with the car, cleared them and reprogrammed the original and the one off ebay.
they both work perfect!
spidertrax spacers coming
going to plasti dip the wheels over thanksgiving break. First matte black then cover with silver metalizer plasti dip for the gunmetal look.
Will be getting a radflo or icon coilover kit from metal tech black friday sale.
How did you clear the codes. As I am in the same boat want some extra keys made it was only sold with 1 and my computer is already full of keys....that I dont have.
you should take your worries and questions to that first link in your sig :D
^x2! Could we get some pics of the fender close up? Curious of gaps and open spaces. Looks good and would help me fit my 35's!
What do you mean? I got 2" from my icon extented travel at their factory setting... then I cranked it about 3/4" higher with preload and the ride is still amazing. I could take measurements for you if you want. I've got the icon extended travel remote resis and total chaos UCAs. PM me if you have any questions.
follow the programming instructions and on the part where you turn the ignition on once to enter program mode. turn the ignition on and off 5 times instead and that will clear all the codes. then program the fobs using standard programming instructions found here http://www.programyourremote.com/classified/Browse.asp?cid=283
I think step 4-E is where u substitute five on off Ignition turns to clear all fob codes
also had to go through all steps for each additional fob it would not let me program all at once for some reason
key was 8.00
Is that 458 Win Mag brass?
Replaced my 1" tweeters with 3.5" full range Infinitys
IMG_20131116_235510_zps482797f2.jpg~original
IMG_20131117_004019_zps78e2c0dd.jpg~original
Widdled out some sliders yesterday. 1.75x.120 DOM. I will be welding them on but I am going to wait until I lift the T4R and get some real tires.
Mock up
Mock up
I really like the kick out, that's the first time I have seen it done this. I really like that the bend goes around and meets the interior tube,mist I have seen become the outer tube
I've had the OW spec Radflo 2.0s and now Icon 2.5 extended travel, and I'll never run Radflo again. At the preset height, I got 3-3.5" from the Icons. I had to really crank down on the Radflos to get the same lift.
