Just installed some 06-09 tails! Pretty damn easy. I love this look.
Finally installed my rock sliders, Stubbs welding HD-SKO. Call Richard and order your set today. Awsome guy to work with and the quality is top notch.
info on mounting of the hella lights you have. i got a pair of lights the other day and looking for some mounting ideas
Added the right side audio controls for the steering wheel.
Installed the remote PAC steering control for the Kenwood deck.
Worked the first time, that's always a big plus!
Replaced the blower motr that was chirping with a new denso unit. (the old one was a denso, too which worries me. It had 11-14 written on it. Makes me wonder . . . )
I'll just keep my fingers crossed this blower motor lasts. They aren't cheap.
So no additional hardware required for mounting?
None. I did a pilot hole into the bracket that holds the speaker after marking the guides. It sits good and flush with the door panel as well when installed. I mounted them in the bottom of that bracket. With the wiring up.
Work with stock system or are you running another amp?
This is with stock jbl amp for the door speakers.
Hmm sounds pretty straight forward. I'll probably order these in the next few days. Thanks LTDSC!
I raised the front end to see if I could reduce the rubbing... what a difference an inch makes! It actually ended up 1.063" higher and it only rubs on the passenger side at almost full-right lock now. I still need to get an alignment, but feel that I've made some good progress! The bottom edge of the front fenders are now sitting at 38-11/16" from the ground... seem about right?
Finally got my limited grill (after wanting it for over three years). Now it makes me realize how much work my paint needs.
Finally bolted up my BudBuilt sliders with full diamond plate.
RCI skids are primed and ready for paint...
