Compustar dash dual HD dash camera system. Awesome system
Drove it to Asheville, NC. Long drive but the views are amazing. Definitely wouldn't think this truck has ~90k given how it drives. Makes me glad that I got away from Ford :biggrin1:
Drove it to Asheville, NC. Long drive but the views are amazing. Definitely wouldn't think this truck has ~90k given how it drives. Makes me glad that I got away from Ford, Or I could have been "Found On the Road Dead!!!" :biggrin1:
Fixed it for you at no additional cost :biggrin1:
[MENTION=100305]TiN[/MENTION] just curious, what is the diameter of your RS-720 mount? I've gotten two both 3/4" diameters and I think that's my problem.
was looking at how im going to mount my offroad lights and a friend said i could put them where the fogs are. not going to be replacing my fogs with them but here is what they would look like behind the trim. dont know how they would be mounted but here you go
IMG_20140920_195647_zps6b351add.jpg~original
going to be getting a kc hitch mount and mount them in my cbi front hidden hitch
New LCA's
Replaced my LCA's with new factory LCA's. My cams were frozen so the alignment shop didn't have much to work with. With 134k on the odometer I figured it wouldn't hurt to replace the balljoints.
The two rear cams came out pretty easy, but the two fronts I had to cut out with a Sawzall. What a pain in the butt that was. The whole project took me about 8hrs, but that included a run to HomeDepot for cutting blades and waiting for the paint to dry after I touched up the scratches from the saw blade on the frame with chassis paint. I also painted the LBJ brackets that bolt to the bottom of the knuckles since I had them off.
My advice to anyone doing this is to have all cams/bolts in hand prior to starting and assume you will have to cut them out......if not, consider yourself very lucky and just return the parts that you don't use.
I found this guide to be very helpful front LCA removal & bushing replacement - Toyota 120 Platforms Forum
photo1_zpsadc6c16d.jpg~original
photo2_zps8951be56.jpg~original
photo3_zps33efa86c.jpg~original
photo5_zpsc9780806.jpg~original
My next big project will be rotors, pads, and calipers all the way around.
photo4_zpsec54305c.jpg~original
Went out into the desert to do some shooting with friends. Guns we brought: M&P Pro 9mm, AR15, 12 gauge, 20 gauge, Ruger 10/22 i-TAC, Sig 2022, Rossi .357 revolver, and a Browning .22 lever action.
A lot of lead flew today!:AK47::gun6:
My world is over! :Cry:
Here is to hoping my @ least "depreciation value" will double in the next 1,000 miles.
Ambrose67
