Cool! Where did you get that? Was the installation tough?
It's a stock Toyota part. Part No. 74110-35010-B0. I found it on eBay for about $30.
Seeing your thread, I head to fleabay and saw someone offer $43.94 or best offer. I offered $35 and he took it. Should of offered $30, uurghhh
Anyway, coming in next week. Not a smoker, but having extra outlets is always nice.
went to the lake before it gets too cold
I see you're in Australia. :pound:
forgot that older 4th gens only had one front outlet
Mine's an '06. I din't know any came with more than one outlet in front.
Next up for me is to install an outlet in the rear of the center console so my kid can charge her phone/watch movies on road trips.
yea i am looking at adding more outlets as well. i dont know how hard it is to add on to the console back but i might look into that as well as another on the dash or side of the console.
i think its 08 and 09 only but here is what it looks like
IMG_20141019_122400_zps1ce09538.jpg~original
Woahhhh whattttt!?!?! Center console window switch for the tail gate?? That's awesome!
Australia?! hahahaha what do you mean?
Installed the "Smokers Kit" ashtray so I now have two power outlets. :rockon:
By far one of my favorite mods, so nice to be able to plug both my phones in at the same time if needed
Part number!!!! Please!!!!!!!!!
WOW, completely forgot about the tailgate switch being moved to the center console on the 09s. Would be nice if someone got a part number! :eyebrows:
Anyway, I'd install this over the smokers kit. Would need to:
1) run the wires from the dashboard to the floor center console (easy)
2) Place the hazard button to where tailgate switch was (where it SHOULD BE)
3) Find something (some switch) of use for the blank. Hmmmmmmm
Working on my puddle/turn signal mirror covers now. Taking a coffee breake........
smileys-coffee-578570.gif~original
Tried to find the part number. No dice.
Can anyone help find the part number??
Also what does the plug for the window switch wiring look like? Wondering if I'll have to get creative
58844-35020 is what i saw on the bottom. i would check at a dealer to make sure but thats what i saw
as for a switch for the blank i had i did this
the hazard button does not clip in to the hole. if you take out your window switch and hazard you can compare. i just put zip ties on each clip and slid it into place. once again i would check and make sure i got the part number right before buying
IMG_20141019_164919_zps9c810371.jpg~original
Refinished and reattached the stock skid plates. Had to drill out 2 broken off bolts the PO hadn't bothered to deal with.
Replaced all the spark plugs. They were the original NGK/Denso split. I sure hope they were changed in the past. :suspicious: V6 so every 30K is prescribed. Runs soooo much nicer now though. :clap2:
Replaced all the spark plugs. They were the original NGK/Denso split. I sure hope they were changed in the past. :suspicious: V6 so every 30K is prescribed. Ran soooo much nicer afterwards though. :clap2:
What did you do with the bolts you drilled out? Tap new threads? A few of mine were busted so I took an air hammer to the weld nut in the frame and just stuck a thru bolt/nut with some big fender washers. Worked great to date.
delislerebecca
