Cleaned up under the hood, it was dirty. And ordered new tires. Should be here Friday. Excited about my price tag heart attack! -.-
Finally got a chance to take a few pictures. Just got it about 2 weeks back. I've been lurking on the site doing research for a while and then this deal popped up.
Thinking about starting a build thread next week.
It's a 2005 4wd V8. About 190k miles.
Ran through Flagpole Knob off of 33W here in Harrisonburg. I went out in my 4runner while my buddy was in his pathfinder. While the trail is pretty mild, that which the pathfinder struggled with, the 4runner took it with ease. Ice was really the most difficult to navigate and there was plenty of it.
Can someone explain why my pictures are never right side up when they show up normally everywhere else?
a few guys from the richmond area are going up there the 24th
[MENTION=86063]wyanrard[/MENTION] do you want to post on here and see if anyone else wants to tag along?
Nope, no RCAs. Here's the parts I used:
PT546-00120-AD Antenna Adapter- (You'll only need the part that plugs into the antenna)
PT546-00120-CH- Accessory Harness Adapter- Steering wheel controls, etc.
Metra TYTO-01- Converts the analog output of the head unit to the digital signals the Synthesis amp is looking for.
71-1761- Reverse Wiring Harness- Allows you to plug the converter into the Scion head unit without hacking up any vehicle wiring.
Optional:
PT546-00120-US- USB/Aux Adapter
PT546-74120-MC- Bluetooth Mic, but also necessary to enable bluetooth functionality for A2DP streaming.
Just purchased a 1819 for my non jbl 07, I also order the Antenna converter, audio cd deck and the bluetooth mic. Did i miss anything?
I did that a couple weeks ago to the front cab mounts, I was amazed at how much crap came out. I'll be doing that more often from here on out.
I could see mud caked up to the holes in the frame. It had hardened like concrete, and there was no way to rinse or scrape it out without the pressure washer. Some of the same mud fell on my driveway when I did some work on it and scraped it out of the front skid plate, and it didn't wash away for weeks despite several rain storms! There was at least an inch or two of it inside the back of the frame, and less in front.
Are there any other easily accessible holes? I got two in the back of the rear wheel well, and rectangular ones in the front of the front wheel wells. I also sprayed out the inside of the tubular V8 hitch. It was dark so I couldn't really get a good look while I was at the carwash.
Now that I cleaned it out, I'm afraid I'll have to clean in there on a regular basis because there's no longer a protective coating of mud! I should have waited until after winter to do it.
Well, Today, I tried to crawl under the rear of the 4runner because I've been hearing a metal to metal vibration. Come to find out, its the Gibson tail pipe hitting against the tow hitch. Has anybody had this before? I tried to push the tail pipe end to towards the passenger side so it clears without touching or vibrating against the hitch. TEMP fix, but has anyone run aftermarket exhaust hangers? (To any and all of my Subie people out there) Kind of like we do/did with the Polyurethane Cobb/Kartboy extended exhaust hangers..
Installed air lift bags. I think the firestone bags install easier but these are in now so I'm hoping they last.
Mine is rubbing against the cross member over the rear axle. Drives me nuts. After a bunch of research the one issue with Gibson I found is that they move unless you replace the clamps with a band style clamp. Without the band clamp they wiggle themselves around and then are clocked wrong and rub stuff. I plan on having the joints welded on mine once I get the headers and all that so that it can't move around anymore.
Optional:
right on, thanks for this list! i knew there had to be a way to do it!!
[MENTION=74494]Az4runnin[/MENTION]
Bought these... much needed replacement. Can't wait to put em on. Got them for $200, so can't go wrong. :whoo:
as i promised....
the lights and already trimmed reflectors courtesy of [MENTION=165]momo.75[/MENTION]
img_20150120_133224_359-jpg.1313
and the oem switch retrofitted (modification required) in my center console
img_20150120_141555_343-jpg.1314
Monday afternoon we popped over to the beach to watch of one our _amazing_ sunsets. It’s the corner of the intracoastal, nice area (AWD only) that opens into the ocean here in Vilano (that’s the Old City St. Augustine across the river).
