made some custom yellow covers for the hella 500ff's. they match the color of the fogs when off but when on my fogs almost look white. night will tell how they really look
20150327_193019_zpsl6wgvuhh.jpg~original
FB_IMG_1428016572925_zpsjpbqsvpi.jpg~original
20150403_173805_zpsd7wiprvc.jpg~original
20150403_173952_zpsqly6s0r6.jpg~original
<----------Did this a few moths ago 4wd worked for a while. Then it didn't.
Today I started troubleshooting found this FML. When i pop it open water and mud came out smelled horrible.
Finally got this yesterday Now picking a winch since my 4wd doesn't work LOL.
I kicked my 05 T4R 4WD Sport for the first time today. I have owned it for 4 days now. I went to take the wheels off, to replace the brake rotors & pads on the front, only to realize it had locking lug nuts on each wheel. I then discovered that the vehicle did not include the key to unlock them.
Went up to Windrock with a few friends today. Yet again, I was surprised at how well she does for a RWD. (Excuse the cockeyed antenna...)
IMG_4955_zpspukjytqw.jpg~original
IMG_4939_zpsuyxn6xmx.jpg~original
IMG_4959_zpsdlwsqwqg.jpg~original
IMG_4969_zpsycf12inx.jpg~original
Finished up installing my FJ Springs and shocks and Daystar rear spacers to go along with my Maxtrac Spindles:girl:
Holy sh!t, where did you pick up them bad a$$ FOXS, how much you pay, how much flex with you get with them? Been thinking about a up grade myself.
From the backyard scrap pile for the price of free and half, who would've thought there would be a pristine set of 18" fox coilovers sitting back there. Somehow fits in the factory coilbucket too!
One of mine broke on my 3rd gen so I purchased this: http://www.amazon.com/Advanced-Design-ATD-3060-Locking-Remover/dp/B000OUUGJG/ref=sr_1_5?ie=UTF8&qid=1428119757&sr=8-5&keywords=lugnut+remover
1 minute with an impact wrench. Worked like a charm. I also think some tire shops will remove for free or a nominal charge.
Decided to go gray headlight housings and upgrade my projector lens
Stock
Gray with new lens
Them on close up
Picture doesn't do the cut off and sharpness justice
Still no justice but better shot
Them on vehicle
Stock
Gray with new lens
Them on close up
Them on vehicle
Looks good, I'm gonna have to open mine back up to seal them correctly, condensation after painting them black. Was fine all winter just happened now, oh well. Anyone know where to get replacement lenses for the headlight housing?
Are the lens worth the switch? Easy to swap them out? I've been meaning to do this swap.
I think so. The 4Rs already have some of the best halogen projectors out there. They do well with hids but only doing a true hid projector retrofit will you do it right and keep everything legal if that's a concern for you. With the new lenses I can see a little further, there is more width and the overall fullness of the beam pattern is really good. An added bonus is you have a little bit of a color flicker at the cutoff line as well as the sharper cutoff as seen in my pics. It's easy to swap them out. Once you have the headlamp assembly apart it's just another set of screens that old the projector in. The lens is held in with just 3 tabs. Popped out the hold and put the new in and throw it all back together and enjoy. And for $40 for new lens or $25 for "blemished" lens it's a good upgrade. I'm very happy with them.
I'll have to double check but I think Toyota does. I know they sell replacement lenses for the 3rd gens cause I looked them up for a fellow guy at work. But it cost almost as much as the whole assembly. I'll put my vin in and see if that applies to us 4th gens.
I got this put on
20150404_155709_zpskw3c7xas.jpg~original
then started to work on the transfer case plate. I got the cross member on then I went to take off the tube supports. Then this happened
20150404_180616_zpsg1kx2flv.jpg~original
Thats right all 8 bolts broke. What was left was very badly corroded. Already broke 3 drill bits trying to drill new holes to tap. Also one of the bolt holes in the radiator support bracket for the front plate is completely stropped out. Going to either get a time-sert in there or might just get a longer bolt and put a nut on the top of it.
Ambrose67
