Picked up four of these bad boys to go with my lift. Everything's getting installed Thursday. I'm hoping I didn't get them too big. They're 275/70/18 the lift is a 3/2 Toytec lift. I also got a 1" body lift but told the mechanic not to put it on if it's not needed. I think it might be. We'll see.
You don't need the 1 inch, send it to me I'll throw it away..lol, if I were you I'd put it on, more lift, never a bad thing
Sent from my SAMSUNG-SGH-I747 using Tapatalk
placed an order for my "surprise" Father's Day/Birthday gift from my wife and kids. I didn't think she could top last year's gift of my Demello front bumper.....wrong....:thumb:
Armor is a grand gift indeed! ^^^^
I'm also finally getting the dash replaced on Thursday! Only a 9 month wait, but it's finally almost a sure thing! ;)
Finally got around to replacing my front brakes with 5th gen calipers, SS lines, new pads and rotors. I also ripped out my XREAS and put 5100s on all 4 corners. It was a long day.
The braking is a massive improvement and no more vibration. The ride is a bit better too.
Finished installing the Ironman lift ...
Massive difference over stock (especially old worn out stock).
Change my spark plugs with oem. One of my coil packs looks a little worrysome.. Any ideas what could cause this?
Looks like a little oil got up in there.
Sent from my SM-N920T using Tapatalk
Leaking valve cover gasket.
Sent from my SAMSUNG-SM-T337A using Tapatalk
Got the front end lifted ... Vast improvement in looks and ride. I've taken measurements all around and while Ironman says 45mm (1.77 inches from stock) for the front, I got significantly more than that from my saggy old setup. Pics to come once I finish the rear, either today or tomorrow. But for now, a comparison pic ...
Did you get the nitro gas or foam cell?
That's what I'm hoping. A lot of people have had problems with cylinder six so of course I assumed the worst and thought head gasket. :/ I'll look into valve cover gasket though that's a whole lot cheaper to fix haha thank you for the input!
What year is your truck?
Got the regular FoamCell (couldn't afford the pro's)
Rides nice, rear is pretty firm though. I suspect it will be better with a bit of weight once I get setup.
I have the regular foam cells in the front. I also installed them with the extra collar in prep for a bumper. Once the springs break in they will soften up a bit.
Just picked up a 2000 limited yesterday. So today was about a good cleaning on the inside and tomorrow I will start with some of the maintenance it requires.
Well, I replaced the spark plugs, which were quite old. The previous owner didn't have spark plug replacements listed on his log so not sure when the last change was.
Then, I made a second attempt at replacing the upstream air/fuel sensors; this time through the wheel well. Turns out it's ridiculous no matter which way you go and I could not get an angle or leverage from any direction. I gave up on that job.
The brake caliper looked gross, so I cleaned and greased it. Hopefully it's not frozen again
BillM777
