FS roads between I-90 and WA-410. I can DM you the actual coordinates if I can find them :D
That'd be awesome man!! I've explored a lot of logging roads around here and other popular hot spots where a lot of other people go mudding and what not, just looking for somewhere a bit outta my area where the family and I can go and get outta dodge for a bit! No problem if you can't find them, I'm sure I could possibly find something on google if all else fails! Haha
Ton of great places out that direction. This particular one had great sunset and sunrise views. I'll DM you with it later once I've looked at my map. Pretty sure I had GPS tracking enabled
Where is that exactly? Looks like the trail up to the abandoned church but then again, a lot of North Georgia trails probably look similar.
Charlie's Creek Road. No abandon church that I'm aware of. Are you thinking of High Shoals Road or Nimblewill?
Had this installed today, With remote start
Sent from my iPhone using Tapatalk Pro
I added this USB audio charger with an Add-a-Fuse
View attachment 261073. View attachment 261074
to accessorize my recent Kenwood radio install.
View attachment 261077 View attachment 261075 View attachment 261076
Now I can charge and connect to Kenwood via USB for added functionality!
I added a pair of those but I spliced into the cigarette lighter and used an inline fuse. I might add one inside the center console instead, I don't really like having the USB cables sticking up right there. If you use the port closest to the armrest be careful when you flip down the front part, it will bend the USB cable.
Finally replaced my worn out hood struts after my rig tried to decapitate me one too many times. Got the Strongarms from Amazon for about $50. It just lifts up on its own, rather forcefully - kinda hard to close. It was the exact opposite before! Made this gif from a video I took on my phone, hopefully it works...
Also installed a yellow top Optima D27F, needed some more juice for my winch. Embarrassingly, I ordered an Optima group 35 (620 cca) yellow top a few weeks ago, not realizing I could fit a lot more in. It worked fine but there was so much extra room, I searched and realized I could fit a 27f - 830cca now, should do just fine.
So I have 2 good batteries sitting in my garage, I guess I'll sell on craigslist.
Lift (icon stage 2), TRD pro wheels with 34x10.5 tires, powerslot rotors and metal tech rear LCA, CVJ axles and stainless brake lines.
Pulled my brothers rear end. He was in a hit and run that bent his axle tube. Diff guy said $200 he can straighten the tube. Took about six hours to pull. Sucks because we are going to Moab in a week.
From the beginning of ownership, I had a portion of my top grilles paint completely fadded away so I finally got around to pull the front grille, sand it down, and prep it to be painted tomorrow.
Busy 2 days...
Wife's:
Changed Engine, power steering, and trans oil.
Changed coolant
Partially cleaned and primed rust
Mine:
Changed power steering and trans fluid
Changed coolant
Put 5th Gen(2017) TRD Trail front suspension in. About 1 1/4 in of front lift.
Waiting for a rear axle seal from Toyota for the wife's truck. "We'll get it tomorrow" was 5 days ago.
Convinced the "boss" I need different tires and possibly a little lift out on Medano Pass today. Slipped on the rainy road and hit the mudwall though. :dammit:
Swapped my front brake lines to SS and flushed the system. Brakes so much nicer, bleed was long overdue
Also, my 4R feels small [emoji24]
Plasti-Dipped
Removed the clear plastic instrument cluster cover for cleaning. It had stains on the inside around the reset button from the PO. Anyone else this OCD?
delislerebecca
