Went to the beach, took some photos...
Installed 4 new spider trax 1.25" wheel spacers
Test fit all 4 new wheels and tires..
Did even more body mount trimming, fender trimming, bumper trimming, and now that pinch weld is staring at me because it knows its about to get beat.
The rear fits perfect, no trimming required.
I am ready for the alignment now, and then ill be doing more trimming!
I tried to read through your build-thread...just tired/sleepy. So, what suspension lift do you have up front beside the 1" BL? How much lift and how high from ground to fender with the 285/75/17's? Thanks, just an awesome and very handy built. Your 4Runner looks even better now with the new tires!
Someone previously cut off the bolts holding my skidplate on, then tied the plate back on with zipties, or so the mechanic said...
Drilled the old bolts out and tapped 10mm threads in place. Two went just fine and two didn't go so great, but the plate stays on now.
I had something similar happen to my rig. If you keep having issues look into nutserts. You can get a cheap kit at harbor freight.
I traveled the country for the last month. Learning the limits of myself, my 4runner and my family. We had a great time.
Coast to coast
Our whole adventure is on Instagram! [MENTION=138179]Overland[/MENTION]_tennessee
Namibia - Sossusvlei
Just returned from a mini-African road trip...
Went to Namibia to explore the Sossusvlei region...rented the 4R's African brother, the "Fortuner" in South Africa...
..and then took a sunrise photo with another legend...
Thanks man I appreciate the compliments..
No body lift on mine, just a wheel spacer for more offset/clearance recently installed. I havent measured in a long time ground to fender height but I will after new tires are fully installed and aligned.
JBA uniball Upper control arms painted silver
Radflo 2.5 ext travel coilover with adjustable remote Resi's and 700# springs (overland warehouse valving)
Radlo 2.5 ext travel rear shock
5th gen Radflo 2.0 springs with daystar 1.5 spacer
Skyjacker Extended rear sway bar links
Front sway bar delete*
Energy suspension Poly rear sway bar bushings
HD XRF Outer Tie Rods - (April 2017)
(replaced lower coilover spacer bushings April 2017)
New OEM Genuine Toyota LCA's and cam bolts (july 2017)
4 -1.25" Spider Trax wheel spacers (Sept 2017)
Finally installed the Battery Doctor isolator and ran cable to cargo area. Now, in one of the cubbies above the wheel well, I have an Anderson connector to keep my portable power gen topped off while driving.
I hate to start a new thread after searching but is the 115V button supposed to light up when the lights are on? Not the little activated light but the backlight
New tailpipe.
Resonator delete.
Routed behind the tire.
285/75/17 c load Nitto Ridge Grapplers on FJ wheels.. installed!
Got my 3/8" synthetic winch line from southeast overland in the mail today.
Amsteel Blue 3/8" grey 19600 lbs with Factor55 Splicer and rubber isolator
Test fitted the DIY drawer system...so far so good!
New lower ball joints. Pain the the ass. In the past I have used a real press. I don't have one at home though so did it with the C clamp type. It works, but makes a 45 minute job 3 hours. Oh well, hopefully never again.
For anyone wondering, the Moog LCA ball joints work great, seem well made, and are manufactured in the USA. $27 each vs $360 from Toyota.
