Painted my roof rails with Rustoleum satin black.
Got it washed. :shrug:
Besides that, I topped off the radiator overflow tank with pink stuff. Gonna order some bits and pieces later tonight though. :biggrin2:
New valve stem seals went in today. I shot two retainers across the basement on reinstall and found both. Woop!
Cleanup and heads go back on this week.
Started modding the garage to better organize my shit lol
did you apply the floor covering or did it come like that?
i am getting to the point with my place where i can think about
the garage flooring (or leave it cement) and a new work bench :)
I paid for a company to do it before I moved into the garage. They leveled it with floor grinders and filled in any cracks prior to applying the coating. It was pricey but well worth the investment. Only time I curse myself is when I drop a bolt or washer lol
Just ordered the parts from Toyota that I need to do the rear diff breather mod.
90404-51319
90930-03136
Going to also order 5/16" silicon vacuum line from amazon. Any reason to use fuel line over vacuum line? Seems to me vacuum line would be the better option.
90404-51319
90930-03136
I'd think fuel line would be a bit more durable/harder to accidentally pinch shut
Just got done cutting and welding up the body mount chop plates from MetalTech.. looks good enough and functions just fine under normal conditions... still get a bit of rubbing when turning into bumps at speed.. but that's expected, right?!
Sent from my SM-G935V using Tapatalk
Finished up the plug job today.
Cleaned up the coil packs.
Replaced the old hardware while I was at it. Looks out a place but that’s okay. I’ll eventually dive deeper once it’s cooler out.
Was also able to use the extra fender washers to secure the air box plate properly.
How many miles you running?
90404-51319
90930-03136
Fuel line is rigid compared to a floppy vacume line and would be more resistant to kinking
(*edit... I didn't look to see your response KCDEHART, sorry im not trying to step on any toes.)
