MikeinNH67
Senior Member
Got the wife a little something.. which will share a driveway with the 4runner, that counts right?
As long as you get to drive it too.
Had this for probably at least 6 mos. Finally found a buddy that had a 220v welder. Didn’t get any before pics but definitely very close to level now for the pan hard bar. Had a pretty bad angle previously. 4Runner handles better on bumps, and bounces more vertical at higher speeds instead of wagging like it did. Feels more stable in higher speed turns as well.
I need to get under there with a wire wheel and clean the whole underside up and then paint.
Still need to do mine. Just trying to brush up on my welding before I jump in.
Just a heads up, it’s a pretty good fit on the front and side but the back has a pretty big gap and hard to access from both sides. Just an fyi to plan for that. Taking the rear driver tire helps a lot.
Finally got the 4x innovations sliders fully on. Thry look great.![]()
Sent from my SM-G970U using Tapatalk
Thanks for that. Ill be removing the wheel and spring when I do mine. The more space the better. Did you weld the inside too, or just the outsides?
Thanks ! I'm on 35s. 12.5 wide i believe.Looks good! What size tires are you running?
Just buy those 35's already momo lol, I see you doing the research on all the associated threads.Looks good! What size tires are you running?
Yep, I have a Daystar 2.5/1.5 on mine and it just doesn't feel solid on the highway. Once I get back to my dad's garage, I'll bust off the lower frozen strut bolts and get the lift outta there. Was fun for 40k miles, but I prefer controlThrew the RC 3” spacer lift on and some 285/70 AT’s on AR wheels. Looks great, rides like a pile of garbage lol. Couldn’t leave it stock so this will hold me over until I have the money for the 3” Pure performance kit.![]()
Sent from my SM-G986U using Tapatalk
Installed my new fridge (ARB Zero 63) and drawers I built . Still need to make my wings and filler pieces for the drawers, but almost there!
