What do you guys think?
barefootaggie
I Recently had a Full 4x4 FJ suspension installed on my 2wd and thought I would use toytec 1/2 spacer to help level out the front but I didn’t use it because I would of got reverse rake. The FJ coils gave more lift than I thought about 2.25"in the front and .5" in the back. The measured the before and after from ground to wheel well and this is what I got: Front before 32.75" After 35" Rear 35.75" After 36". I want to go a little higher all around maybe an inch. I still have the front toytec spacer so now I'm looking for a rear spacer. I love how I have still an inch of rake and would like to keep it that way. I'm looking at either a cornfed 1" or daystar 1.5" Is the cornfed worth the extra $70? What would you do?Also is there any extra things I need to do like aftermarket upper control arms or sway bar relocates?
Front Before:
After:
Truthfully? It's hard to tell from the angle you shot the side picture from but it looks pretty level.
If you add another inch you will be going above 3" so you might look into the diff drop kit, they are pretty cheap from toytec. What size tire are you going with?
FYI I'm new so bare with me
I wanted about an 1" more all around. Do I still need a diff drop since its just 2wd?
are you going to be upgrading to a bigger tire?
Also i want bigger tires like some BFG all terrain or along that. What do you think/recommend?
You will not need a dif drop kit since you dont have a front dif.
Right now I have 305/70/16, and I have a 3" lift. I love the bigger tire.
I had the TA/KO AT before I got my wrangers.. I loved them for sand / rain / dry. I hated them in the mud.
So what do you think about a little more lift? With the FJ springs it put me with a 2.25" lift in the front and .5" in the back. So i still have the toytec 1/2" which sould give 3/4" to 1" in the front then i will add a 1" cornfed or 1.5" daystar in the rear. Does that sould good? All togher it should give me 3" fornt lift and 1.5" rear lift.
Depends. More lift never hurts. But if you only do 1.5 in the back ur nose will stick up. I am not sure how you feel about that. But if you go to 2 in the back you will have a leveled runner...
Personally I think a level car looks better.
I would go with the 1.5 in the back if it was me.
i agree with the 1.5.
im actually having jason get me a 3/1 cornfed bc the 3/2 still have a little rake.
and im putting fj springs on as well.
TerryNap61
