talonjade
Just pulled this off Toyota owners site about my truck... what does this mean? it looks like the transmission was replaced on 10/12/10... I have always though my truck revved a little high on the HWY is it possible its still broken and its not shifting into overdrive? :sobbing: anybody have a translation? THANKS!
10TOZZCHEC 10/12/2010 *CHECK ENGINE LIGHT *CHECK ENGINE LIGHT ~|~CUSTOMER STATES CHECK ENGINE LIGHT IS ON, CHECK AND ADVISE ..TRANS WILL NO GO INTO OVERDRICE..SEEMS TO BE SHIFTING IRREGULARALLY ~|~.ERROR CODES P0710. P0712, AND C1201. TESTED COMPONENTS RELATED TO ERRORS. INTERNAL TEMP SENSOR FAULT. ..ROAD TESTED FOR CONCERN VARIFY DELAY OF SHIFT, SLIPPING WHEN SHIFTING AND WILL NOT GO INTO OVERDRIVE. ..INTERNAL DEFECT TO TRANSMISSION ASSM. ..REPLAC ~|~..AUTH #R0278069 1-800-888-5245 ..CUSTOMER HAS A $100.00 DEDUCTABLE ..CUSTOMER RESPONSABLE FOR TAX ON REPAIR PER CONTRACT. ..FAX TO 615-967-3525 FOR PAYMENT. ............................. ............................. . INFORMED CUSTOMER AND EXTENDED MAINT
Parts
Name Part # QTY
ATF T-IV QUART 00279000T401 5
REMAN ATM 350103G47084 1
CUSTOMER PAY
05TOZ 10/12/2010 ***TRANSMISSIONS*** ***TRANSMISSIONS*** ~|~EXHAUST HARDWARE NOT COVERED PER EXTENDED WARR ~|~REPLACEMENT OF TRANSMISSION
Parts
Name Part # QTY
BOLT, FLANGE 9151281035 2
NUT 9017910070 4
BOLT, STUD 9011610149 2
BOLT, FLANGE W/WASHE 9167480828 1
BOLT, W/WASHER 9011908B75 1
GASKET, EXHAUST PIPE 9008043028 1
GASKET, EXHAUST PIPE 9091706083 1
BOLT, W/WASHER 9008011229 1
RING, O 9030109011 1
CUSTOMER PAY
10TOZ 10/12/2010 ***ELECTRICAL*** ***ELECTRICAL*** ~|~..16 PIN CONNECTOR FOR TRANS DATA CONNECTED SEVERLY CORRODED. POOR CONNECTION ~|~REPAIR CORRODED DATA CONNECTOR NOT COVERED THROUGH CUSTOMERS EXTENDED MAINT PLAN
Parts
Name Part # QTY
HOUSING, CONNECTOR F 9098012293 1
TERMINAL, REPAIR W/W 8299824250 15
Parts
Name Part # QTY
CUSTOMER PAY
Parts
Name Part # QTY
NUT 9017910070 4
CUSTOMER PAY
Parts
Name Part # QTY
