What head bolts to buy. 95 T4R
Slowerthanyou
Im in need of new head bolts for my 1995 T4R. I would like to know what head bolts are best and what everyone has been using besides OEM. Thanks!
I've had good results using ARP studs on other projects, although I've never had to take the heads off my 3.0 I'd recommend them. Buy quality if nothing else, OEM is always a solid choice.
Not looking for eBay parts by any means, just looking for other good quality bolts for good prices. OEM stuff is always very pricey and there's always other good options for less money.
fel pro
Just got done using two boxes of FelPro, thought they were plenty good enough at $23 per head/box.
They needed washing before use.
Used washers can be fine, lightly wet sanded on a flat plate, Just a clean up, not enough to alter parallelism.
It is important your washers are in good condton if you want that torque to translate to an even clamping pressure.
Can't remember the last time I have a problem with any FelPro goods.
Reinz and Beck are typically made in the First World too.
The cheapest I saw Toyota OE were just under 10 bucks for bolt. No thanks.
It is important your washers are flat if you want that torque to translate to an even clamping pressure.
Yea I called toyota and they want $230 for 16. I did however go with the FelPro. For a great price.
AndiGarage
