What is this tube?
It looks like a vacuum line that activates the 4wd. Should run up to a manifold looking device with a couple electrical plugs and another hose
I hit the awd button in the side of the transfer case shifter and I heard the clunk which made
Me believe it was in 4wd, as well as the light stopped blinking after the clunk. I really don't want to replace that damn thing.... Especially. If I have to remove the power steering rack and pinion again!
you shouldn't have to remove the rack, but if its going in and out of 4wd i can't be the vacuum line...
Thats just the vent for the actuator, Your good but try and find a way to seal it. Ive seem people epoxy it back on with good results
2001 and 2002 actuators are all electrical. I managed to break mine off a while back, I really should find a fix before I drive through a big puddle and it breaks.
That's for the help! I think I'm going to take a toothpick with grease on it so that way the inside stays clear when I try and JB welded back on will see if it works
Jhunt
