schneidermj
Been looking at new tires and will most likely stick with the Nitto TG's but am curious if there are any benefits of going with an E load rated tire. Pros or Cons?
Will be looking for tires very soon. What are the stock tires- C? I certainly do not want E. I'll go with C or D- probably whatever came stock or whatever is recommended by Toyota. I don't like overly stiff and bouncy rides and at most, will be towing a pop-up camper.
Stock tires are typically C or Standard (4 ply). Run them at 35-36 psi. If you go with what Toyota recommends they will be at 32 psi with a slightly softer ride, worse gas mileage, and shorter life.
I'm posing the question because I recently tried the Hankook Dynapro's and they bulge waaaaay to much.
I am running them at 34 but 35-36 will work well..maybe better. I need to buy a compressor since I prefer 30 when on forest service roads. So a D may be the ticket for you if you can find them in the brand/model you want. Are you looking at the Hankooks or something else now. I can tell you from personal experience that the Michelin LTX in E will wear like iron....and feel like it.
Let us know what you end up getting. All this info helps when we make tire decisions.
P rated GYWSA, these are stiff enough as is
Isn't "P" a speed rating or am I too much of a newbie?
Will be looking for tires very soon. I certainly do not want E. I'll go with C or D- probably whatever came stock or whatever is recommended by Toyota. I don't like overly stiff and bouncy rides and at most, will be towing a pop-up camper.
I ended up going with the Nitto TG's P rated. I figure they worked for me before so don't screw with it.
I'd get the D load rated version if it's an option but C is still a much better choice than E for what you described as your driving.
I ran D rated Nittos for 5 years and switched to C load rated Duratracs and am very happy with either. E is way too much for a truck weighing only 4000lbs and simply to harsh for a daily driver.
