What OBDII reader are you using with Torque?
Majindan
I have an el cheapo I'd bought off Ebay a couple years ago, and it connects but none of the sensors show up in Torque. This thing works in my wifes new Kia, but not my 02' SR5. What would you guys recommend that actually works?
thanks
This is my current one: https://amzn.com/B01C6CZ0SQ and it reads all the KIA sensors, but cannot read anything from my 4Runner. (although indicates it is connected to it) A cheap wired code reader works fine but only gives error codes, I need to use Torque to see what my lean/rich percentages are to troubleshoot something.
This is the one I have:
https://www.amazon.com/gp/product/B005NLQAHS/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
Along with the reader, I highly suggest getting this OBDII extension with shut off switch so you don't have to pull your reader out every time. The reader will continue to pull a power draw even with the ignition off so if you let it sit long enough, it could drain your battery.
https://www.amazon.com/gp/product/B00UR5XBMW/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
I used velcro to affix the reader in the bottom tray under the cigarette lighter and ziptied the extra cable under the dash. I also wrote "on and off" with a sharpie. Other than the benefit of being able to keep the reader connected without worrying about draining the battery, I like that the reader is no longer near my right foot when I'm using the accelerator pedal. I've accidentally bumped it a few times with my foot but not hard enough to break anything. Now that it's out of the way, I don't have to worry about that either anymore. A final benefit is because the OBDII port faces downward, gravity is working against you. On a bumpy fire road, my reader actually fell out but I no longer have this issue anymore.
Here's some pics of my set-up:
You got the right one. I have the same thing and it works great on my '02. Lots of imitators, but the "real" BAFX is super cheap anyway.
If you're talking torque, No. Mine reads in 1/10 degrees for engine and trans. Maybe a setting has it doing that on yours? :cowboy:
Thanks, I've checked all the settings. Just wondering if it could be the cheap $12 adapter I'm using. Might order a new one and see if it changes.
Just started using the Bafx, leave it plugged into the OBDii connector full time with a switch for the power wire to the connector in the center console, lighted to make it harder to forget to turn off.
D'Angelo
