What rear springs to run? 890?891? ....
99Yotarunner
Hey guys just another question, what rear spring should i run on my 4runner, im thinking the 891 because i haul my motocross bike around alot on the rear hitch on my bike hauler, so the rear sees about 300lbs of extra wieght right off the receveir. will a 890 be to soft a spring? i dont mind a lil bit of a stiff ride if thats what a 891 will do? also will the 891 lift the rear a lil higher then a 890 due to being stiffer rate...?
890s are a little taller but 891s are rated for more weight heres a pic of some 891s i took out vs stock
IMG_1523.jpg~original
I'd say 891 if your going to be hauling your bike. Reason I went with them cause I plan on pulling my sled.
OR LC spring like everyone seems to be doing now. Was going to go that route at first but I didn't see much info on it at the time.
