afg10000
Just bought this '98 Limited to replace my destroyed '96. Started swapping all sorts of things today and found this sticker attached to the underside of the dash cluster. I already know it was born in Canada, that's not my issue. The 4WD symbol doesn't work on the cluster and I was swapping LED's anyway, and bulbs did not fix the problem, (OEM or LED). Also, the right turn signal light won't work no matter what bulb I put in there. The low gas light came on after I put a new LED in the socket. All the other bulbs swapped just fine. I'm thinking I have a wiring problem from whomever pulled the cluster and changed the odometer. Any input?
