I had a problem with an aftermarket rear camera which went in short, since then no power to the radio neither the mileage remaining nor outsite temperature displays.
I checked all small fuses including Rad1 but all checked good.
Also check the fuse at the radio and good also.
There is a gray bigger thing at the bottom which the label at the fuse box says "Noise filter", I checked it with a DMM and reads big resistance in the ohm position and does not beep on continuity.
This is not a fuse so notsure what it should read.
Can some body check this with a DMM and tell me what it reads so I can be sure if this filter is the problem.
Thanks.
Thanks.
