What type of Grease?
southpaw2324
Hey guys,
I appologize for probably asking a reocurring quesiton but I can't find the answer anywhere. What type of grease on our 4th gen's do we use on the drive shafts (zerk fittings?). I downloaded the owner's manual but its tough to find anything in there.
Any help is greatly appreciated!
I think what <<<< said is the correct recommendation from Toyota but from what I've seen the majority of people actually use Mobil 1 synthetic for the drive shaft zerk fittings. That's what I've been using and I've had no problems thus far.
Can you use Moly everywhere? or the Mobil 1 synthetic?
If i do use the moly everywhere or Mobil 1, do i need to take the fittings apart and clean them all first or are the Lubes cross compatible?
I can tell you I didn't clean out the drive shaft before I put the Mobil 1 in there. I'm not sure how much of the original grease (if any) was left in there.
The reason that Moly is recommended for the slip yoke is because a Moly grease is considered an extreme pressure grease, which works better and lasts longer for the slip yoke. The u-joints are better served using a litium or synthetic grease. You could use either of them in the slip yoke, but it won't last as long or work as well at getting rid of the "clunk".
Ok so then why not use Moly for everything?
You could. Moly is much thicker and wont spread or disperse as well which is why a multi purpose grease is recommended in the other areas. I think they just state the best for a particular application. Kind of like paint. . . .some types work better than others depending on what is being painted, but does not always mean the others wont work.
youngrk
