^^^^^^ Agree 100% with above.
With good tires you will be amazed what a stock 4Runner will do with a good driver in it. A rear locker helps even more.
Blue
You guys have convinced me to stay stock for now as far as lift. Going to pick up a set of airbags for the rear and when tires are due plan to pick up some 265/75's.
There is a guy local to me that has an e locked 4.30 third. He wants $400 OBO. Does this sound reasonable? I need to find out if it comes with the actuator. I know some of the 4runners were pre wired in the dash for the rear diff lock. I need to pull it out and see if it has the wiring.
There's another guy here on the forum that has a 4.30 front diff so I should be set there. I need to see what he wants for it.
I know there's not much of a difference in gearing between 4.10 and 4.30's but I haven't seen any e locked 4.10s around here.
Also, this one I found for sale is from a 96-98 truck. From what I've read the wiring plugs are different from pre and post 99 trucks. I need to read the FAQ but I'm assuming this is not a drop in third since mine did not come equipped with the e locker originally?
Nice looking 4Runner! I can believe those mpg numbers. The 5 speed seems to make a big difference in fuel economyI have a 2000 4runner with the same 5-spd and open 4:10 rear. I installed the 99 talls with Bilsteins and firestone airbags about a year and 15,000 miles ago. I highly recomend the air bags. The combination has been able to get me to most places I've wanted to go, and with no sag when loaded with gear. Considering I'm married to the glamping queen that's saying something.
I too hope to find a locker some day, but since this is my daily I hesitate to take it much further. My truck has a VERY compliant ride, and I consistently average 21-23 mpg. I'm not sure why my fuel consuption is so good!? As far as fuel tank size, if I spend an extra couple of minutes at the pump I can easily get an additional two gallons in the tank, bringing my range to around 350 miles.
All said though, if this wasn't still my daily I'd probably like to add another couple of inches in ground clearance, just in case. Picture was taken at Imogene Pass about two weeks ago.
Good find, looks just like mines same year too. Lol
Really ready to lift this thing or get some 265/75/16's. Have put a little over 3k miles since I bought it and itching for it to be higher.
heres you a 4.10 elocker axle pretty close to you...... https://fayetteville.craigslist.org/pts/5345174829.html
great looking Runner, glad to see another forum member so close (thought I was the only one). I'm only about 30 minutes from Greenville
